what stall for TR224 cam
Old Jun 9, 2006 | 04:32 PM
02NBMFormula's Avatar
Default what stall for TR224 cam
as ive read the stall must match the cam or visa versa so masters of the f-body's, what stall do you recondmend for a TR 224 cam at 114 lsa. (what stall speed and STR) also what brand would you suggest for something strong and effiecent???
thanks
Old Jun 9, 2006 | 04:56 PM
98A4LS1's Avatar
I run a 3400 2.1 with 3.23 gears which seems to do the trick for a street driven only car. 224/228 112+1.
Old Jun 9, 2006 | 06:39 PM
SSPEEDY's Avatar
In sig. If it wasn't for my 1-2 shiftpoint being off 500rpm, car would be about a tenth and mph quicker.
Old Jun 9, 2006 | 08:32 PM
RevGTO's Avatar
Pontiacerator
IMO, the perfect match for a 224 cam is the TCI SSF3500.
Old Jun 10, 2006 | 05:54 PM
any times on that car???
so far im thinking around 3400 2.1 but what about the brand??? from what ive read, tci is loose and not as effiecent as a yank or vig.
Old Jun 10, 2006 | 10:56 PM
4mula's Avatar
face it, youre car is slow and quit youre bitchin
Old Jun 11, 2006 | 09:50 AM
SSPEEDY's Avatar
hmm, my best ET is a 12.02 at 111.8. A couple weeks ago I pulled a 12.04 at 112.25. Still has more left in it.
Get back in line again Mark
Old Jun 11, 2006 | 09:54 AM
BlackHawk T/A's Avatar
Keep in mind that a converter designed for a stock LS1 is going to stall a bit higher when you start putting more power through it.
Old Jun 11, 2006 | 10:05 AM
Sport Side's Avatar
I like that approach also. Medium sized cam for a broader torque curve and a decent sized converter for very quick ETs at the track.
Old Jun 11, 2006 | 02:40 PM
RevGTO's Avatar
Pontiacerator
Not true ... the TCI 3500 is not loose at all compared to comparable offerings from other mfr's, and efficiency is good as well.
Old Jun 11, 2006 | 07:34 PM
SSPEEDY's Avatar
PI converters are not known for efficiency. Yank is top dog when it comes to that.
Old Jun 11, 2006 | 09:08 PM
AK's WS6's Avatar
Agreed. They are good converters, but they do lack effiency.
Old Jun 12, 2006 | 05:56 PM
so its between yank and TCI. also will i be losing any power on the top end with a stall???
Old Jun 12, 2006 | 09:38 PM
JNorris's Avatar
Moderator
I ran my TR224 cam with PI Vig 3200 stall. However a Yank 3600 or TCI 3500 will do just fine as well.
John
