MY fuddle track fun
60ft- 1.98
330ft- 5.50
594ft-7.90
1\8mile-8.43
1\8mph-83.99
i was looking for 85mph and a 8.3 but o well it wasnt my night and im pissed off
i don't think it is the converter. that time is right for your 60'. you need better tires.
i went 8.18 @ 80 with only a 4k fuddle, lid, and 373s - stock tune on everything. i bounced RL like 5-6 times on each shift, which is what caused the low trap. i would look elsewhere for your problems. with a hard hook i would expect that converter to average low 1.7s with full weight and bolt-ons.
the first time out this year with my converter i went 12.85. changing NOTHING but my driving i have knocked of .52 (12.33) just from practice and TIRES.
That 60' needs work and it sounds like either 1 of these 2 things: 1 you are flooring it from idle or 2 you stall it up then floor it immediately. Those won't help you with your time so try footbraking it at 3000 first then release the brake, once the car hooks, floor it. Once you get better, footbrake it higher. If you spin, you did it wrong. Even a little spin can add as much as 4 tenths, so no spinning!! The bfgs are supposed to be stickier than the nitto drag radials, so get into the 1.7s-1.6s with them.
