going from 2:73 to 3:73...worth it?
Yes, neutral drops will destroy the transmission more quickler than almost anything else you can do besides getting it really, really hot.
When I broke my rear end in my cam only A4 I had a 4k stall, ET streets and was pulling low-mid 1.6 60's. The posi/spider gears broke.
i was just trying add to the humor of this post since it was so far off topic.
hope everyone can think of a time when they seen this, its hilarious to watch!
....gears will either cost you little money or will be very expensive.....you can spend 1500 bucks on your 10bolt....if your gonna spend that much save up and get a 12 bolt
10-bolts break even in relatively stock autos. get over it guys, it's well known.
and no, to my knowledge he was never doing neutral drops. he could break the tires loose at 60 mph, no need for neutral drops.
