4k stall or 4.10s...or both?
Old Jul 6, 2006 | 11:52 PM
cha1nz1535's Avatar
Default 4k stall or 4.10s...or both?
like the title says.
I just wanna beat the cocky sob down the street in a race
Old Jul 7, 2006 | 10:09 AM
Kraest's Avatar
I vote for 3.73s and a 4000 stall.
Old Jul 7, 2006 | 12:08 PM
cha1nz1535's Avatar
any one else?
Old Jul 7, 2006 | 12:34 PM
monicaz28's Avatar
Most people say 3.73's in an A4. I run 4.10's and a 4200 stall, and for my comination of mods, it works great. It really all depends on what other mods you plan on doing. That's overkill on a stock car, but get a cam that's in that powerband along with other supporting bolt-ons, and that combo would do you right.
Old Jul 7, 2006 | 12:39 PM
jessedale98's Avatar
put a 100shot on it with drag radials and be done with it.
Old Jul 7, 2006 | 04:52 PM
SVT THIS's Avatar
What cam are you running? Most think 4.10s in an A4 would be rough. I plan on doing it but I am not everybody. A 4000 stall and 4.10s will make traction nearly impossible with street tires so expect to pay a premium for drag radials every 3-5k miles. If your rear end is a "3" series carrier (stock 3.42 gears) Thunder Racing has a set of 3.90 gears you could run. That would perform pretty well I imagine.
EDIT: If you choose to do just 4.10 gears or just a 4000 stall, do the stall. It will make a MUCH larger difference than the gears.
Old Jul 7, 2006 | 05:49 PM
LC's Avatar
LC
hmm I'm waiting my 4.56 spooled 12 bolt to go with my Fuddle 4200... Stock engine
Old Jul 7, 2006 | 06:21 PM
SVT THIS's Avatar
Are you going for the SI record or what??
Old Jul 7, 2006 | 06:36 PM
cha1nz1535's Avatar
i dont have a cam right now...im thinking of just gettin the stall and holding out on the 4.10s for a bit
Old Jul 7, 2006 | 06:58 PM
LC's Avatar
LC
I don't think my car will break any records running at 8000DAs
Old Jul 7, 2006 | 07:23 PM
radz282003's Avatar
My brother runs a SS4000 and 3.73s. He loves them. On MT DRs he' s gone a best of 12.41 and a 1.6X 60'. Those 3.73s really shorten up the tranny shifting though. First gear is damn near worthless on the street, and pretty much uses 2nd when he AutoX'd. At the top of the 1320 he is running in the powerband really good though. I like my 3.23s and probably wouldn' t do 3.73s. Once I can get a clean run on some DRs and compare to his times, I can make a better judgement though.
Old Jul 8, 2006 | 02:36 PM
WeeWolf's Avatar
if you plan on putting it on the juice go with 3.73's i have 4.10 with a 4000 and with a 26 et street i come out right at 6500.
Old Jul 8, 2006 | 03:00 PM
BlackHawk T/A's Avatar
You guys aren't considering the fact that with these automatic overdrive transmissions, a gear over 4.xx is probably going to put you into OD in the 1/4 mile. Great if you want to trash your tranny and your ET's...
My .02
Old Jul 8, 2006 | 06:08 PM
cha1nz1535's Avatar
Alright so are you guys saying i should get the 4k stall. Look at the mods, is this the way to go? Getting a TC is the next mod.
Old Jul 8, 2006 | 07:56 PM
Jpr5690's Avatar
4000 Stall And 3.73 Is My Vote
Old Jul 8, 2006 | 08:11 PM
Honda Hunter's Avatar
I'm with this manly man
Old Jul 8, 2006 | 10:23 PM
AK's WS6's Avatar
Do the stall and call it good.
Old Jul 9, 2006 | 06:01 PM
cha1nz1535's Avatar
What size stall?
Old Jul 9, 2006 | 06:13 PM
Ed Blown Vert's Avatar
Stall and sticky tires
Old Jul 9, 2006 | 08:09 PM
cha1nz1535's Avatar
ne thing on stall speeds?
