Worth going from Y3000 vs. ST 3500??
Old May 28, 2002 | 01:45 AM
Gearhead's Avatar
Default Worth going from Y3000 vs. ST 3500??
I have a Y3000 in the LT1. How much of a performance increase (in terms of reduced ET and increased MPH assuming traction) would there be in going up to the ST3500? Also, would the ST3500 offer a noticable improvement from a roll, say from like 50-100? Thanks in advance
Old May 28, 2002 | 02:14 AM
AlonzoVersion 1.0's Avatar
Default Re: Worth going from Y3000 vs. ST 3500??
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Gearhead:
<strong>I have a Y3000 in the LT1. How much of a performance increase (in terms of reduced ET and increased MPH assuming traction) would there be in going up to the ST3500? Also, would the ST3500 offer a noticable improvement from a roll, say from like 50-100? Thanks in advance</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">All I can say is yes everything will increase.Now performance for the buck I cant answer because I dont know how many car lengths it will give you or how much efficent it is.I am sure someone else will chime in.
Old May 28, 2002 | 07:53 AM
Ragtop 99's Avatar
You'll probably see .1 - .2 gain at the track and some improvement from a roll. The more you have mod'ed the motor for power in the upper midrange and top end, the more the benefit will be.
Old May 28, 2002 | 10:47 PM
OBSSSD's Avatar
With an LT1? I say no. With an LS1 , definately!
Old May 29, 2002 | 10:06 AM
Raughammer's Avatar
D(irecto)r Pepper
Labor wise? do it. It is a more RACE style converter. You will see an improvement.
Cost wise? that is totaly up to you.
Old May 29, 2002 | 10:43 AM
Patrick G's Avatar
LS1 Tech Administrator
You will go MUCH faster from a roll. You will gain about 600-700 rpms in shift extension. That's gonna make the whole thing worth it in my opinion.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old May 29, 2002 | 11:10 AM
TransAmaniac's Avatar
Believe it or not, I changed out my YANK 3000 for an ST3500 and went from a best of 12.34 with a 1.73 60ft to a 11.93 with a 1.64 60ft.
But that's in an LS1 <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old May 29, 2002 | 06:40 PM
schultzsj's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TransAmaniac:
<strong>Believe it or not, I changed out my YANK 3000 for an ST3500 and went from a best of 12.34 with a 1.73 60ft to a 11.93 with a 1.64 60ft.
But that's in an LS1 <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">These two converters and the SY3500 are the ones I have been considering - I have to say I did not think there would be that much difference.
Did you change anything else except the converter? Were the track and weather similar?
Thanks,
Steve
Old May 30, 2002 | 08:56 AM
Actually I did change something. I forgot to mention that with the 3500 I could no longer hook with Nitto's so I went to ET Streets.
The weather was actually cooler when I hit my 12.34 which was at Cecil, I think it was around 50 deg.
When I hit the 11.93 it was more like 70+
<small>[ May 30, 2002, 08:58 AM: Message edited by: TransAmaniac ]</small>
Old May 30, 2002 | 05:54 PM
schultzsj's Avatar
<strong>Actually I did change something. I forgot to mention that with the 3500 I could no longer hook with Nitto's so I went to ET Streets.
When I hit the 11.93 it was more like 70+</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Looking at the 60' times I would not expect the tires were worth any more than a couple of tenths at most so, considering the weather, is still looks like you must have gotten 2-4 tenths from the converter change alone - still quite a bit.
Just got to thinking, though, if you were full-on hooking with the Nittos and the Y3000 then the tire change may not have been responsible for ANY of the improvement. If the tires were the same diameter (i.e. not changing effective gear ratio) and you were not spinning the Nittos you would have run the same 12.34 with the ET Streets and Y3000. In this case the tires would not have make you any quicker they would have just allowed you to put the new-found ST3500 torque to the ground.
Were you hooking at full throttle with the Nittos and the Y3000?
Anyone tried the Y3000 to SY3500 swap on a LS1?
Thanks for the info,
Steve
<small>[ May 30, 2002, 05:58 PM: Message edited by: schultzsj ]</small>
Old May 30, 2002 | 06:22 PM
XLR8NSS's Avatar
Adkoonerstrator
I went from a Yank3200 to a ST3800 in my old car and it was well worth the upgrade.
The car was an absolute animal from a roll. It held real close to 5000rpm on the upshifts with the 3800 compared to 4200rpm with the Y3200. It had headers and a few bolt ons. It was also a LS1.
This was about as loose a converter as I could stand on a daily basis at the time but, I sit in a lot of stop and go traffic so a loose converter can get old quickly....until you get some open road and stomp it once or twice. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
John
Old May 30, 2002 | 07:03 PM
WILWAXU's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by schultzsj:
<strong>Looking at the 60' times I would not expect the tires were worth any more than a couple of tenths at most </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">In Ron's defense, Cecil was slicker than snot that day... I think he could have went deeper with a dead hook <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
