vig 3200 question/possible issue
Old Jun 16, 2002 | 05:28 PM
TomQ's Avatar
Default vig 3200 question/possible issue
Hey guys,
here is the story
just installed the vig 3200, love it, it's kewl and stuff, but after i installed it threw the SES light (Engine Survice Soon), it was on even if the car was running, untill today, i went to egt some gas, and when i was coming abc home, the car died, i pulled over and started the car up again, gased it, and then somehow the car died again, iw as scared and frustred since it happened to me for the very first time, so i'm not sure what happened and why car died, so, anwyays, I tryed to started the car up again, and it srated just fine and the SES light was gone. I got back home, turned the car off and then turned it abck on in like 30 mins, the ses light was gone and the was working fine.
Afetr i installed the vig 3200 it seems to me like its idling a bit ahrder, like it requires more power to idle, has anyone noticed that ?
Anyhow, has anyone has similar experience with thier cars ? i mean , may be my PCM was learning and then decided to reset itself, that's why my car died ?
Any guesses ? I'm really scared about my car.
Thank you much
Old Jun 16, 2002 | 05:35 PM
DriveATransAm's Avatar
Default Re: vig 3200 question/possible issue
first off, you need to learn to spell check.
second- your car will idle lower with the converter, you need to get it programmed to idle higher.
Old Jun 16, 2002 | 07:46 PM
TomQ's Avatar
sorry for the spell thing, i'm too nurvious about the whole thing and my car dieing <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
so, you had the same issue or something ?
Thank you
Old Jun 16, 2002 | 07:48 PM
jimmypop13's Avatar
try resetting your computer, works for some people
Old Jun 16, 2002 | 09:51 PM
TomQ's Avatar
so, if i reset my pcm it will supposed to learn how idle ? i mean it will add new rpm's ?
like before i was idleing at 600rpms and it will change like to 800 or something ?
Old Jun 16, 2002 | 10:12 PM
horist's Avatar
I put a ST3500 in mine
car idled poorer (average was still 550, and standard deviation was 30). I had it die a few times on me in reverse (give it little gas, and when you let off it dies) and a few times in drive (again, little gas).
I raised my idle to 950 and it is fine now <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 16, 2002 | 10:32 PM
TomQ's Avatar
yeah !
i think same thing happened to me !
how do i reprogram it ?
i dont have hpp3, is it the only way to reprogram it, right ?
i guess i will have to find soemone who may do it for me...
Thank you much !
Old Jun 17, 2002 | 12:21 AM
MAXIMVS's Avatar
www.carputing.com
go there. you're gonna need ls1 edit pal <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ June 17, 2002, 12:22 AM: Message edited by: MAXIMVS ]</small>
Old Jun 17, 2002 | 03:56 AM
NX†C's Avatar
disconnect the battery and then reconnect it after about 5 mins and it will take it about 2-3 miles or thereabout, but will re-learn the proper pattern with the upgraded converter. same thing happened with my 3200 and i still have a low idle in reverse and it will at times die after giving it gas and then letting off, but raising the idle through re-programming will correct that. it comes from the IAT counts being bad. good luck with everything though.
Old Jun 17, 2002 | 07:08 AM
Ragtop 99's Avatar
Try the idle relearn.
If that doesn't work and it continues to idle low, turn your idle set screw a half turn open or enlarge your TB hole by 1/64".
IAT = Inlet Air Temp
IAC = Idle Air Controller (which effects idle quality).
Old Jun 17, 2002 | 03:34 PM
TomQ's Avatar
Thank you much ya'll, i'll try everything u have suggested here!
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jun 17, 2002 | 03:42 PM
fastlif's Avatar
first reset the PCM, if that doesnt work turn your idle screw in...some say up to 2 turns w/o setting code, I turned mine 1 full turn and fixed problem. You shouldnt have to drill TB without cam. MAKE SURE ALL IS DONE AT NORMAL TEMPS. It will change if you set when cold.
Old Jun 17, 2002 | 04:40 PM
TomQ's Avatar
PCM reseting(disconnected the bettery) didn't help...
trying the next thing
Old Jun 17, 2002 | 07:48 PM
TomQ's Avatar
and why noone told me that in ls1 stock throttle body there is no screw stock...
i have to drill a hole...
damn <img border="0" alt="[whiner]" title="" src="graemlins/gr_cry.gif" />
Old Jun 17, 2002 | 09:20 PM
RyanJ's Avatar
SSU Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TomQ:
<strong>and why noone told me that in ls1 stock throttle body there is no screw stock...
damn <img border="0" alt="[whiner]" title="" src="graemlins/gr_cry.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">mine has a screw. look on the left side of the TB (facing it) under the linkage deal (the think that moves the TB blade). its there. stick an allen wrench under there and turn.
Old Jun 17, 2002 | 10:25 PM
TomQ's Avatar
what year is your car, mine is 2001
i'll try to look for anything can stick my screwdriver in...
by the way, is there anything else should i know before i'm gonna stcik my screwdriver in and screw it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> ?
any details, steps in order of which i should do everything... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jun 18, 2002 | 11:16 PM
TR's Avatar
TR
No, no screwdriver to adjust the idle set screw. You'll need a small Allen wrench, and (like mentioned by Ryan) the set screw is UNDER the linkage.
If worse comes to worst, I'll post a pic of where it is located. Let me know...
I had to adjust the idle a few times on my 2001 after my converter was installed, so I know how you feel. When you get the PCM reset and the idle adjusted, your car should idle much better (mine sure does).
