Does an auto tranny with a stall need a cooler?
Derek
I went with the big flex-a-lite that summit has, single core, but about 20 x 7 1/2 x 3/4, the one with -6An fittings, I think it's rated at 20K GVW, looks like it should get the job done, if not, I'll put a fan on it.
I agree with putting good lines on it too, with the pressure that they will see, I wouldn't want to risk puttign cheap lines on either.
My thought is this:
Unless your engine coolant temp is constantly well above 200 degrees, the stock cooler is still going to cool the tranny fluid. With my 160 thermostat and fan settings, my engine coolant temps stay at 187 degrees, so the trans fluid should be cooled to near that temp in the stock cooler, and the external should be pulling another 15-20 degrees after that. Just my $.02.
tell your friend to wake up, your tranny would get all tore up w/o a cooler the amount of heat that is generated is unreal so IMO i think ill stick to getting a cooler. IDIOTS
That said, on a 4L60e, heat is an SOB, especially with a stall. I wouldn't consider running mine without a cooler, period. I did use all -AN lines on mine, tranny line leakage will kill a tranny quickly.
overlfow can on the vent and its done. less parts, less weight, and less chance of leaking fluid on the track. ive seen this mostly done in heads up outlaw cars, that only run once in an hour or so. your normal driver or weekend bracket racer NEEDS a cooler.
fwd guys are dumb.
hehe.
Why even try bothering not puting a cooler with a converter? A B&M 24,000GVW cooler is like 50 or 60 bucks. I couldn't understand the rational of not wanting to put one on over that kind of money.
BOSS APPROVED!
