stall to big?
Old Sep 5, 2006 | 03:39 PM
transamfreak01's Avatar
Default stall to big?
so people are starting to tell me that the stall i was planning on gettin is to big for my cam. 239/242 649/609 and i am still not sure what lsa to get... 2300-6800 RPM Power Band with a peak around 6400rpm. any ideas
Old Sep 5, 2006 | 04:36 PM
jmm98LS1's Avatar
If you're planning on spraying it I'd stay under 4000.
Old Sep 5, 2006 | 08:18 PM
yeah but with my cam dont you think i am losin power with goin with a big stall?
Old Sep 5, 2006 | 09:08 PM
BlackHawk T/A's Avatar
No because if you don't go big, you won't get into the powerband of that cam.
Old Sep 6, 2006 | 09:58 AM
so do you think i should stick witht he 3600??? this car is a weekend cruiser and mostly keep for the street..... not so much track
Old Sep 6, 2006 | 11:09 AM
jmm98LS1's Avatar
The 3600 will stall closer to 4000 when you spray. I personally think it would be a good converter for your setup.
Old Sep 6, 2006 | 11:17 AM
monicaz28's Avatar
I woudn't go any tighter than what you have. I have the same cam, and would like to spray it also. My stall is a 4200 and I plan on keeping it. I am curious what your rev limiter is set at. You might want to raise it a bit, but other than that, sounds to me like you've got a good stall size.
Old Sep 6, 2006 | 03:11 PM
SDB's Avatar
SDB
I would go Yank SS3600....4000 is too much on the spray, I found out the hard way. I have a 382 with big cam, etc. and on a 175 shot, it would blow right through the PT4000 converter I had....now I am going with a SS3600.
SDB
Old Sep 6, 2006 | 03:57 PM
bjamick's Avatar
yes a 3500 or 3600 is perfect for the MS4 im getting the same cam and im getting a TC built for my car from PTC here in alabama, for only $450 and getting it shipped to my door. these will work well with nitrous also. do not go with a 4000 stall WAY to big..
Old Sep 6, 2006 | 04:08 PM
yeah ive been hearing about tc being built.... would that be somehting i should look into or just stay with a yank 3600?
