4l60e question
Old Sep 8, 2006 | 12:41 AM
99WS-6T/A's Avatar
Default 4l60e question
ok a friend of mine has a 99 trans am (not ws-6) his transmission automaticaly shifts him into 2nd even though he has it manually shifted in to 1st. is this normal because mine does not do that?
Old Sep 8, 2006 | 03:44 AM
MrCadillac's Avatar
thats normal. unless you have a tran-go HD2 kit, or the trans programed to shift higher, it will protect itsself and shift. my caddy would do that.
Old Sep 8, 2006 | 05:10 AM
BlackHawk T/A's Avatar
It depends on the year of the car. My 2001 would hold 1st.
Old Sep 8, 2006 | 09:15 AM
performabuilt's Avatar
LS1Tech Sponsor
Some 4l60e will upshift when in manual low others do not , this can be fixed in one of two ways , Programing is one solution and the transgo hd2 kit is the other , The hd2 is the definate fix ,
PerformaBuilt
Old Sep 8, 2006 | 02:00 PM
99WS-6T/A's Avatar
thanks guys
Old Sep 8, 2006 | 02:06 PM
import slayer's Avatar
my 2000 will not shift automatically if I put it in 1st, and I dont have a shift kit
Old Sep 8, 2006 | 03:20 PM
LS1Tech Sponsor
As I was saying before some 4l60e transmissions factory will hold the gear forever virtually others will not and i have seen them thant will not hold past 3500 rpm , its in the programing of the ecm but im not sure why ?
Performabuilt
Old Sep 10, 2006 | 03:37 AM
MrCadillac's Avatar
my cadillac would hold 1st to 5000. but then again, it was a 94 cadillac. The caprice came witha trans go, and has a trans outta an unknown year f-body. so I will never know about that one.
