Problem at the track with 3rd in the 4L60
Old Sep 19, 2006 | 11:20 PM
JGKadell's Avatar
Default Problem at the track with 3rd in the 4L60
I did a nice burnout on my ET Streets, launched decent and when it went to 3 it just went straight to the limiter. As I came on the return road it would catch in the upper RPM in 3rd. In 1st and 2nd it was fine. The fluid looks clean, but smells a little funky.
I let it sit for a while and drove it home without a problem.
Did I just get the clutches overheated or a band?
The trans was just rebuilt in March.
Old Sep 20, 2006 | 05:50 AM
GoFast908Z's Avatar
3rd gear is the first to go out usually. Time for a new tranny, or soon at least.
12.2 on a stock a4 tranny? you were tempting fate.
Old Sep 20, 2006 | 04:01 PM
TJ's Avatar
TJ
common problem. there is no cure.
Old Sep 20, 2006 | 04:14 PM
02 BLK WS6's Avatar
Give this guy a call Jake. Tell him that I sent you. I will be getting mine done soon.
Non sponsor link
Old Sep 20, 2006 | 04:29 PM
s346k's Avatar
mine did the same thing...tuning cured the problem so far (15 or so passes ago, it has knicked the limiter once since then). i'm running 12.25-12.30 with my stock tranny, as well. mine is the factory tranny with 63k on it..and roughly 75-80 track passes.
Old Sep 20, 2006 | 04:40 PM
speedo's Avatar
Mine did this also about 500 miles after a fresh rebuild. Three hours away at the track.... Shifted fine going down the road but would only do it at WOT. So the next week I was driving it to my cousins shop to trouble shoot and possibly swap trans and some old grandma was in my way so I put it down to pass and BAM!! it shifted. ???
Fluid looked clean also, possibly some junk in the valve body... Cousin told me once I got there can't fix it if it ain't broke......
Funny guy.... but has been working ever since.. Have about 500 miles on it since no issues with the 3rd gear shift at WOT.
Just figured I would share my story since it sounded the same.
Old Sep 20, 2006 | 05:48 PM
02 BLK WS6's Avatar
A temporary cure is to lower shift extensions, but from what I have been told once it starts you are on borrowed time. With normal driving it might last 100,000 miles, but with stock internals it won't last with abuse.
Old Sep 20, 2006 | 07:38 PM
94z28L's Avatar
i had the exact same problem, with a trans cooler and all, im pissed at the builder to say the least and he will be replacing it seen as his warranty is still on the transmission
Old Sep 21, 2006 | 06:06 AM
JGKadell's Avatar
Builder is honoring his warranty that technically expired on Sept 8th.
Old Sep 21, 2006 | 07:23 AM
NXZ28's Avatar
I have went 11.03 on my stock tranny. I do have a shift kit in it from Trans Go and a Fuddle 4000 converter. Mine got caught in Third gear once and the only way to get it to downshift was manually. When it did, it would clunk really bad. I thought the tranny had finally discovered it was just stock and died. I let it sit for about 30 minutes and then it was fine. I noticed when I put in my shift kit that one of the check ***** had indented the seperator plate. I think this is common for the LS1 4L60e. I think you have to replace the plate and install plastic / ceramic check *****. Someone correct me if I am wrong.
Old Sep 21, 2006 | 01:09 PM
LS1T/A4's Avatar
My trans did this also going into 3rd gear, I had the trans flushed at the Chevy dealer and hasnt done it since, 60k miles original stock tranny, streetraced often, has about 10 track passes on it.
Old Sep 22, 2006 | 01:03 AM
1999Z28's Avatar
if i had to guess jake, sounds like the 3-4 clutches burned up. I dunno what was originally done but if they didn't have the right clearance, they won't last long or as they should.
Old Sep 23, 2006 | 07:00 PM
WeeWolf's Avatar
thats been an issue with gm for a while. 700r4, 4l60 pretty much all the overdrives i've seen this on.
