Brand Of Tranny Fluid Are U Using!!
I don't keep it in there long enough to worry about it. In fact, it's time to change it now.
I only put about 5000 miles on it before a change, and I change the filter every other time.
Cheap Insurance, IMO.
I work at Advancr Auto - when we recieve shipments, it all comes at once, from all different brands. We recieved one shipment of Advance Auto brand ATF, along with Valvoline ATF. A customer bought the Advance Auto brand, opened it up, and it was clear fluid with a gooey/sticky consistancy. It also smelled terrible, not anything like ATF THe Valvoline brand was fine, no issues at all. We called the company, and their answer was "its fine we just forgot to put the dye in" - yea, along with half the other ingredients as well
I also picked up some advance auto brand Brake Cleaner for my friend, thinking "its the same as CRC", but it totally sucked. It worked, but not nearly as well as other brands like CRC. It came out with hardly any pressure and the can was empty pretty quickly, also didn't do a great job of cleaning.
I can go on and on with examples of the store brand being inferior, believe what you want, but my opinion is a good 80% of it is garbage.
you care about - or more. The planetary engagement
clutches, the band and the torque converter clutch.
Out of GM these were all selected / spec'd to be all
happy with common DexIII as you'd expect. When
all that was being worked, bet that synthetic ATFs
were not so commonly available, and perhaps not
part of the process.
In the name of fuel economy our 4L60E is controlled
with the bare minimum of presssure applied, based
on a stock motor assumption and backed up with
an adaptive learning for pressure w/ slip. Good thing,
right? Yeah, for your Aunt Mabel's unmodded Z28,
as if. The learning makes your pressure relax when
things are going smoothly and then gets surprised
and slips whilst playing catch-up every unusually
hot day, or event. Computers is stupid.
With adaptation constantly positioning you on the
edge of slip, no wonder you see it occasionally.
And every occasion stands the chance of adding
a little bit more glaze to your clutch surfaces. Or
popping the slip codes.
Anyway, factory frictions and stock output is one
thing. Increase the output, lessen the grab (by
slipperier fluid), maybe fool the airflow with a
voodoo mod or two, and your PCM will not have
the clue to command the -needed- line pressure.
Reduce the TCC clutch radius (one component of
torque), maybe use a set of clutch components
from an OE design that was smaller so as to fit
(but smaller, always comes from a smaller motor
and was designed for less breakaway torque), why
not throw in a non-OEM converter clutch material
system while you're at it (just for fun) and then
depend on adaptation to bring the pressure on up
to compensate for it all? Reliably? Yeh.
Friction modifiers are added to -raise- the friction
of clutch material against the steels. Super. Make
up for some of the problems from small components
and low line pressure per load. But down in the guts
the good ol' bronze bushings of yesteryear have
been replaced by plastic ones on account of it
saved GM a penny and a half per unit. Plastic
bushing on steel shaft looks not so unlike organic
clutch on steel plate, only bushings are not supposed
to have their friction increased. If you take and put
some old-school "super shift magic goo" in there,
formulated before people were so clever as to use
plastic in the powertrain, that's a roll of the dice.
Snake eyes being a chowed bushing that only can
be gotten to by a full teardown.
Note: a transmission service only relaces about 1/2 of the fluid! where as a transmission flush changes all of it (about 16 quarts i think).
ps: I typically keep a vehicle for 6 or more years and I have never had a tansmission failure in over 30 years due to above practice I believe. However it may also be that i don't flog it to bad.
Hope this help.
Nothing fancy just plain old dextron III any brand is fine.Vince
