View Poll Results: WHAT BRAND TRANNY FLUID ARE YOU USING?
CASTROL
9.62%
VALVOLINE
17.31%
MOBIL 1
16.83%
OTHER
56.25%
Voters: 208. You may not vote on this poll
Brand Of Tranny Fluid Are U Using!!
Old Apr 23, 2007 | 05:44 AM
  #61
FireChicken02's Avatar
I was wondering if the synthetic fluid would be different for a built 4L60E? I have redline ATF in mine (the one geared more towards firmer shifts) dont remember? but I have a shift kit in mine, new bands, clutches, etc. 5 pinion front and rear... anyways its only got 5K miles and although I have never taken it to a track or really raced I have loved the way it shifts? It really FIRM, with only 365 rwhp it has spun pretty good going into second with 315s and a 3.42 what do you guys think?
Old Apr 24, 2007 | 01:40 PM
  #62
performabuilt's Avatar
LS1Tech Sponsor
We have people running both happily so we really dont have a preference,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 24, 2007 | 02:22 PM
  #63
SuperZ's Avatar
What about on a TH-400?My trans builder told me to use non senthetic Type F.is that aright?
Old May 6, 2007 | 04:03 AM
  #64
matt94z's Avatar
I use Castrol Type F non synthetic in my th350. That's the only fluid my trnny builder recommends. It's suppose to hold up better with heat.
Old Jun 7, 2007 | 09:42 AM
  #65
5301113's Avatar
Originally Posted by bjamick
go with royal purple, they are made for performance.
+1
Old Aug 3, 2007 | 07:02 PM
  #66
Batmobile-WS6's Avatar
Default Amsoil for everything
http://www.amsoil.com/storefront/atf.aspx
Old Sep 20, 2007 | 08:00 PM
  #67
383lt1impala's Avatar
castrol mercon
Old Sep 20, 2007 | 08:06 PM
  #68
XpEdItIoUs's Avatar
I used B&M Trick Shift fluid on my th400. It worked perfect.
Old Jan 7, 2008 | 05:21 PM
  #69
DeltaT's Avatar
I always heard that B&M Fluid was just expensive Type F fluid, nothing special. The Type F fluids have a less slippery additive package that firms up shifts.
Jim
Old Jan 7, 2008 | 05:33 PM
  #70
SSlow1's Avatar
I use Royal Purple ATF in my built 4L60E
Old Jan 7, 2008 | 06:32 PM
  #71
curtisad's Avatar
I go with the advance store brand!
Old Jan 7, 2008 | 07:03 PM
  #72
ChocoTaco369's Avatar
Tech Resident
Doesn't matter as long as it's Dexron III and NON-SYNTHETIC! I wouldn't put synthetic in my 4L60E if you paid me. I'm trying to NOT burn up the clutches, and minimizing friction in the tranny fluid is a great way to maximize your chances of smoking clutches.
Old Feb 29, 2008 | 08:54 PM
  #73
Jimmy P's Avatar
I voted other. John Deere tractor hydrualic fluid in mine with a hint of some ATF for color only.
X2 for me
Old Mar 2, 2008 | 10:22 AM
  #74
caldercay's Avatar
Originally Posted by sixvi6-camaro
same here.. Valvoline Dextron III if the trans is ever hungry. No synthetic nothing fancy trans fulid. Heck my FLT trans had a sticker on the pan that says to only use dextron III I think it even says non sysnthetic.
My FLT (not yet installed) has the "Use Dexron III" sticker on the pan.
And actually, I hadnt noticed the sticker until I painted the tranny.
Previous to knowing that, I emailed Chuck (at FLT) and asked if I should
run synthetic for improved friction reduction and to prolong the life of
the tranny - I said I didnt care if it costs more, if it's better, I'll run it.
He said to use either. I think it might be a good idea to email Dave at
Yank to see what his thoughts are.
Old Mar 3, 2008 | 10:21 AM
  #75
caldercay's Avatar
Sent an email to Dave at Yank and this is his reply
(hope he doesn't mind me quoting him)
"We do not recommend any types of full synthetic oils - they can be too
slippery. In a motor where you have metal to metal wear that is great
but when you are dealing with friction materials such as clutch plates
and the converter lock-up clutch you can make them too slippery and
have issues.
I would go with the III.
Best Regards
Dave Myers
Yank Performance Mfg."
Chuck (FLT) prefers the use of III, but said I can run either. I think
the consensus is to run Dexron III, which is what I'll be running.
Old Mar 3, 2008 | 10:43 AM
  #76
Websy21's Avatar
Good stuff I like it, what about brand now, LOL
How are you guys breaking in your trans? When do you change the fluid at first?
Old Mar 3, 2008 | 02:45 PM
  #77
omcar's Avatar
Wolfs Head
Old Mar 3, 2008 | 03:34 PM
  #78
GregWS6&z28's Avatar
what about a mix, say 80% John Deere fluid and 20% Dex III?? I hear to run dex for the anti-slip and anti-foaming additives, and I need to tighten my converter up 150-200 rpms. I'm running a SS4000
Old Mar 3, 2008 | 03:58 PM
  #79
3pnt4maro's Avatar
cheap stuff...works fine
Old Mar 9, 2008 | 05:18 PM
  #80
z-ya's Avatar
Mobile 424 tractor hydraulic fluid.
