th400 have to manually shift? better et?
Old Jul 17, 2002 | 09:48 PM
highgmc's Avatar
Default th400 have to manually shift? better et?
I am thinking about getting rid of my 4l60 and getting a yank th400 kit.
will I have to manually shift the car at the track for a good et? or will it shift itself at like 6300 rpm?
what exactly is a lock up converter? this needed?
will I get a better et with the th400?
thanks! <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old Jul 17, 2002 | 09:56 PM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
Default Re: th400 have to manually shift? better et?
I just got an ATI TH400 and convertor for under $2000.00. You can use your stock tranny mount and your stock shifter. Get a dipstick tube from Madman Racing. You'll have to get a driveshaft made. Use your stock tranny cooler lines.
As far as the ET's dropping, I dunno. I am waiting on my driveshaft to be made right now.
Yes you will have to manually shift the car.
There is no lock up convertor for these trannies. (There is but the tranny/convertor combo is mega $$$)
Old Jul 18, 2002 | 04:28 PM
highgmc's Avatar
sounds like the flp 4l60 is the one to buy then
anyone in the 10's with the flp?
Old Jul 19, 2002 | 12:30 AM
Colonel's Avatar
You can have a TH-400 setup to auto shift. They used to come like that from the factory ya know.
Old Jul 19, 2002 | 12:35 AM
Colonel's Avatar
About the ET...
You should be slower with the TH-400. It's heavier, more parasitic, and has a less than desirable 2.48 1st gear ratio (this can be changed to 2.75 for an extra $400 or so.) The 1st gear of the 4L60-E is 3.06.
Consider that to have the same gearing advantage of a 3.06 1st gear with a 4.10 rearend gear you would have to have a 4.56 rearend gear with a 2.75 1st gear, for example. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Jul 19, 2002 | 06:55 AM
Tim98TA's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Colonel:
<strong>You can have a TH-400 setup to auto shift. They used to come like that from the factory ya know.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">NO ****???? Gee I never knew that. If you were putting it in a station wagon and want a modulator to control when it shifts, that would be fine.
Tim
Old Jul 19, 2002 | 08:30 AM
BIGBOS's Avatar
I would get a manual valvebody...its pretty fun on the street...
I have the "stock"..."race built" Th400 w/a brake....I got stock gearing, but it can handle a butt load of HP...so I never have to worry...first gear has a tiny little delay, but I still pull pretty hard... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jul 19, 2002 | 02:22 PM
Colonel's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Tim98TA:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Colonel:
Tim</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Gee Tim, I really thought you would have known that. I also would have thought you would know that there have been alot of folks to run plenty fast with auto shifting 400s. Learn something new every day, huh? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
