Worried about top end on th350.
Old Nov 13, 2006 | 07:17 AM
ss1129's Avatar
Default Worried about top end on th350.
I recently completed my 350 swap from an m6 car. So Im sitting on stock wheels with 3.43 gears with a 4k stall. On the highway Im at about 55mph at 3k in 3rd. I really dont think my car will make it through the traps without bouncing off the limiter. Is there a way to tell what mph I will be at by about 6k rpm? Im still on a stock tune with all of this. Does anyone know of a way to find out speed vs rpm with out trans gear ratios and just a rear ratio? I love the way it gets up to speed now but Im really afraid Im going to need bigger tires.
Old Nov 13, 2006 | 09:53 AM
dhdenney's Avatar
http://www.richmondgear.com/streetcalculators.html
Well basically you need all the variables you mentioned to calculate the thing but it's so easy to play with. I've come up with 136 mph at 6011 RPM on a 26" tire and 3.42 gear. You're not going to run out of gear.
Old Nov 13, 2006 | 10:53 AM
ss1129's Avatar
Awsome. So a stock tire on my car is 26"? Thanks for the link too!!
Old Nov 13, 2006 | 11:28 AM
ss1129's Avatar
Ok...now when I type in my known rpm (3k) and known speed (55) and known tire size (26) it says I have a 4.22 gear. Im going to say that the speed may be a little off as I paced my g/f at 3k rpms and I was at about 55. So giving that it may be off I would guess a 4.10 gear? Or would a 4k torque converter just throw this equation out the window seeing as I was sitting a 3k?
Im so confused.
Old Nov 13, 2006 | 01:17 PM
jimmyblue's Avatar
Moderator
A3 is not locked on the highway, you need to figure
your "ideal" highway RPM backward from rubber and
gears and compare that to cruise RPM observed. If
you see much slip then forget what you might get
from (6000RPM/cruiseRPM) x MPH - the slip is going
to (mostly) go away at the top end. But at 3000RPM
cruise on a 3000RPM stall speed converter, you're
still paddlewheeling some.
Hope your trans cooler is a big'un.
Old Nov 13, 2006 | 01:39 PM
dhdenney's Avatar
Im so confused.
Someone correct me if I am wrong, the gear calculator on the right hand side of that link is to calculate (approx) a max gear for strip.
Old Nov 13, 2006 | 01:42 PM
dhdenney's Avatar
I understand most of what you mean here but I was a little confused about slip going away on the top end. I thought that's where slip is going to be the worst?
Old Nov 13, 2006 | 02:09 PM
chpmnsws6's Avatar
No, The convertor will be trying to fluid lock at the top end.
Best way to find out is to run it. Your N/A so the worst thing that will happen is you smack the revlimiter (big deal, I did it a 1000 times as an M6 driver)
Old Nov 13, 2006 | 02:26 PM
dhdenney's Avatar
Oh ok I see what you mean.
Old Nov 15, 2006 | 11:07 AM
SouthernSilverSpeed's Avatar
Thats pretty hard to do with no master cylender, clutch, or flywheel. This probably makes no sesnse to most of you, but some people get what I am trying to say
Old Nov 15, 2006 | 01:38 PM
chpmnsws6's Avatar
Huh? instead of locking mechanically via clutch, it tries locking with hydraulics. The two fins inside the convertor are spinning at near the same RPM, or atleast trying to.
Old Nov 21, 2006 | 05:30 AM
ss1129's Avatar
Got it to the track last week. Went 12.57@ 113 through the traps at 6k. Im not too dissapointed with the time seeing as my differential is about useless now. I was like Joe Dirt out there with right tire fire. Cutting worse 60's than with my t56 at 2.01 being the better of the 2.
