Pulled the pan down today couple ?'s
Old Nov 13, 2006 | 08:23 PM
AutomagicLS1's Avatar
Default Pulled the pan down today couple ?'s
Couple questions. My PT4000 has been in awhile now. I wanted to drop the pan and see if there was any signs of crap at the bottom. There was NOTHING at the bottom of the pan no silver crap nothing. Just a TAD little bit on the magnet. My question is though with just normal lightning (bright light drop light) the fluid looks cherry red and smells fine. If you take a flashlight and shine it directly into the fluid in the pan it had some sorta metallic look to it. What causes that? Also i attatched a pic that someone else posted on on here but I marked a red box where I had a question. I belive these are the shift solenoids? One of them was tight and the other one was REALLY lose. I really didnt want to jack with it b/c I wasnt quite sure what they are and I really dont know to much about that stuff. I actually was quite amazed of all the wires and **** right there with the fluid. If that is a solenoid and 1 of them is lose/could be bad. Is this whats causing my PO757 code and screwing with my 4th gear lockup or a tuning issue (no tune yet)? Sometimes lockup works and then it doesnt...... Educate me.
Old Nov 13, 2006 | 11:06 PM
performabuilt's Avatar
LS1Tech Sponsor
Well the solinoids will move a little but if one seems excessivly loose I would suggested at the least changing the orings on them ,Or since one of the possible causes of that code is a faulty shift solinoid consider replacing both of them
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 13, 2006 | 11:08 PM
LS1Tech Sponsor
Oh and the sparkling look could be something but could also be air fine bubbles they look kinda like silver and gold under a flash light
__________________
Call 888-744-6542
Old Nov 13, 2006 | 11:15 PM
Yea thats what it looks like a sparkle
Old Nov 14, 2006 | 08:32 AM
FLT's Avatar
FLT
Nice picture! Your welcome. It would not hurt any thing by changing those shift solenoids. If you need a set feel free to give chuck a call.
Old Nov 15, 2006 | 02:48 PM
LS1Tech Sponsor
Yes thanks for the pic, I have referred people to it a few times , Someone sent me how to post pics but then it says they are to big lol
__________________
Call 888-744-6542
Old Nov 15, 2006 | 10:29 PM
FLT's Avatar
FLT
The 2-3 solenoid will wiggle more than the 1-2 solenoid because it doesn't have a valve behind it with spring tension. Trust me I checked a few valve bodies after reading this post and remembered looking at this once before.
Old Nov 16, 2006 | 12:35 AM
FLT's Avatar
FLT
Default Tuning required sometimes
This code is common with high stall converters in some vehicles, have your tuner delete the PO757 code and the test from the pcm before you do anything. Like Vince said, it's normal for the one solenoid to feel a bit tighter than the other. Once you take care of tuning issue your problem will go away.
I hope that helps with the education.
Old Nov 17, 2006 | 03:18 AM
PBA's Avatar
PBA
I see that you have the vacuum modulator installed, but you did not hook up the pacifier to the epc solenoid plug. This will bring up code problems.
Old Nov 17, 2006 | 05:14 AM
Stuarta's Avatar
That is not his transmission.
He borrowed the picture.
Old Nov 17, 2006 | 08:17 AM
FLT's Avatar
FLT
The epc is the pacifier! Personally I would never use it after having quite a few pacifiers set epc codes. This set up has been tested for years. That is my picture by the way. FYI from FLT.Vince
Old Nov 17, 2006 | 10:30 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Yeh the P0757 and a few accompanying codes are common with high rpm stall converters. If you stall up over 3000 rpm for more than 5 seconds (I think) it throws this code and goes into limp home mode. You really need to tune it out if possible or it'll drive ya nuts. Taking off in 2nd gear and hitting the rev limiter isn't real healthy for our cars either
Good luck!
