How do i check tranny line pressure?!?
I have a 94 4l60e and was just wandering if i have too much or too little line pressure, since either is no good for trannys. so how would i go about checking the pressure? can i use the port that is plugged on left side of tranny? or do i have to get a tuner program to look at it? im kinda in the dark here and would like some light on the matter. i have turned the pcs torks screw a qtr of a turn and added a b&m shift kit. it shifts great . but was running a mustang on the highway last night and when the tranny was shifting to fourth it bumped the rev limiter and kinda had a delayed shift.
Originally Posted by performabuilt
The most acurate way to check it is to use a guage in the port on side of trans,
onn the wot 4th shift what servo do you have for 4th gear
oh Christ, whee can I run 144mph at and not get locked up?
Originally Posted by 02 BLK WS6
Tranny dynos are heavensent.
lt170chevelle it sounds like you might want to lower your 3-4 shift points.
273 SHIFT TO 4TH you are a brave man thats very fast , I would definatley upgrade the OD servo to the sonax super hold its only a few minutes to install and well worth it when that shift happened JUST WHAT DID THE SPEEDO SAY?
something funny is when i had 2.73's in my car when i pretty much first bought it and knew nothing about cars really at all i thought it was cool how fast my car could go. i had went to a speed shop and told them that i just wanted to go faster so thats basically what he did was just a set of basic ported stock 98 heads and a basic 224 cam the car would shift into 3rd gear at about 80ish mph. it was kind of insane.
