4l60e problems...
Old Dec 28, 2006 | 12:08 PM
01'WS6's Avatar
Default 4l60e problems...
I was cruising at about 50 mph this morning and all the sudden out of no where my car will not move in any gear. It has just been rebuilt about 2,000 miles ago with a brand new art carr convertor (junk). Any ideas of what has happened? It quit locking up yesterday afternoon as well and then it just quit. Maybe the pump?
Old Dec 28, 2006 | 12:10 PM
hoover112's Avatar
did you hear any noises before it quit.
Old Dec 28, 2006 | 12:13 PM
performabuilt's Avatar
LS1Tech Sponsor
Ok first lets see if its the pump disconect one of the cooler lines at the radiator put a drain pan down and start the vehicle it should spray a significant amount of fluid in a very short time , If it sprays none out then its the pump , If it sprays alot I would then remove the trans and though rare inspect the converter input splines to see it they are stripped
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 28, 2006 | 12:21 PM
01'WS6's Avatar
Yes i heard a some small clank around like maybe the size of some small ball bearings banging around for a breif second before it went.
And performabuilt i appreciate the advice i do need to do that but i need to get it off the side of the road first so i can check that. lol Thanks a lot for the info!
Old Dec 28, 2006 | 12:33 PM
LS1Tech Sponsor
tow truck time lol
__________________
Call 888-744-6542
Old Dec 28, 2006 | 12:42 PM
01'WS6's Avatar
Originally Posted by performabuilt
tow truck time lol
luckily i got access to a truck and car trailer though!
If it was the pump would i of heard a noise when it went like the clanking around in the tranny?
Old Dec 28, 2006 | 12:50 PM
LS1Tech Sponsor
Not nessesarily if the rotor just split it could be quite sudden and make no noise at all
__________________
Call 888-744-6542
Old Dec 28, 2006 | 01:03 PM
hoover112's Avatar
i have always associated a pump failure with some kind of whining noise. of course i'm not saying that the pump will definetely whine if it's low on fluid or failing, but i've seen several that did. since you heard a noise like ball bearings breaking i would have to assume something broke. problem is it could be in the converter or internal. might need to plan on making a trip back to your trans mechanic
Old Dec 28, 2006 | 01:09 PM
01'WS6's Avatar
I appreciate your info as well. And the trip back to the trans mechanic is already in order. Kinda hoping its the convertor though! And i never did hear any whining.
Old Dec 28, 2006 | 01:10 PM
LS1Tech Sponsor
I figure he will have to do that anyway it works out was just giving him something to check ,As for noise sometimes they do and sometimes they dont
__________________
Call 888-744-6542
Old Dec 28, 2006 | 01:26 PM
hoover112's Avatar
yeah the instructions for checking pump flow are ok if you want to verify flow. i have a feeling he dont have a pump problem though. i also cannot imagine any hard part that would cause a complete loss of pull in forward or reverse, that would have caused it to loose lockup the day before except for the input shaft. even then i dont see it breaking while cruising at 50mph. i'd like to hear what ends up being wrong with it just for future knowledge.
Old Dec 28, 2006 | 01:34 PM
01'WS6's Avatar
I will definately follow up on it once its torn down and we find the culprit. And im sure i was "cruising" 50 and not beating on it because my cruise control was on.
Old Dec 28, 2006 | 01:49 PM
LS1Tech Sponsor
Well its also possible they are unrelated issues , Or possibly the converter clutch came apart and stopped the filter up and resulted in pump failure , Im curious my self to see what it is
__________________
Call 888-744-6542
Old Dec 29, 2006 | 04:44 PM
01'WS6's Avatar
The pump ended up locking up and broke the shaft off the convertor for those who wanted to know.
Old Dec 29, 2006 | 07:43 PM
LS1Tech Sponsor
Do you mean it broke the stator in the pump off the outer shaft that goes into the converter?
__________________
Call 888-744-6542
Old Dec 29, 2006 | 08:11 PM
01'WS6's Avatar
U got me there! lol I dont have a clue. It was broke at the end of the convertor shaft (the only one that i know of that comes out of it) and the pump was in a few pieces. Sorry i dont have a clue when it comes to an automatic transmission or any transmission as far as its concerend! lol
Old Dec 29, 2006 | 08:21 PM
LS1Tech Sponsor
can you take a picture of the broken stuff would be cool to see
__________________
Call 888-744-6542
Old Dec 29, 2006 | 09:23 PM
FLT's Avatar
FLT
Who's TC were you using when it broke? I have seen some lower budget converter hubs break do to improper hardening. Just a little FYI.
Old Dec 29, 2006 | 11:14 PM
Gilbert@Ace Racing's Avatar
Just curious... With the pump dissasembled does it appear to have lost lube? Meaning is it severely scored and discolored or not? Pumps usually do not lock up at cruising speeds under a light load with cruise on... usually start up, hard launches or when towing heavy loads.
It is possible the converter hub failed and took out the pump... that makes more sense to me... probably happened during a PWM event or at 100% lock-up.
I am sure the folks making the repairs will thoroughly inspect it for residual debris. Sounds like you are in good hands indeed.
g
Old Dec 29, 2006 | 11:24 PM
LS1Tech Sponsor
of interest all our units have pwm disabled regardless of pcm setting
__________________
Call 888-744-6542
