which 4l80 flexplate?
Old Jan 10, 2007 | 12:06 PM
MIGHTYMOUSE's Avatar
thanks.
also fyi, the yank 4l80 converter has the ls1 converter hole spacing (4l60) of 11"
Old Jan 10, 2007 | 04:13 PM
NA$TY-TA's Avatar
Originally Posted by MIGHTYMOUSE
thanks.
Thats good to know..... so i take it you are going to use the TCI Flexplate and ARP Bolts for the 4l60E??
Old Jan 10, 2007 | 04:46 PM
thats the plan.. for the 80e that is.
i will be keeping an eye out for the shoulder of the arp bolt to bottom out before the head is tight to the surface and add a washer if needed
my complete automatic combo is
4l80e from transformance
rossler t brake
yank sc3000 stall
tci flexplate
arp flexplate and converter bolts
denny's 3.5" aluminum shaft
hughes dipstick
b&m quicksilver shifter
BMR 4l80e crossmember
energy trans mount
actually i havent picked a trans cooler type or location yet
Old Jan 10, 2007 | 06:21 PM
NA$TY-TA's Avatar
rossler t brake
yank sc3000 stall
tci flexplate
hughes dipstick
energy trans mount
And BS3 controlling the shifts..............
Old Jan 10, 2007 | 08:21 PM
LIL SS's Avatar
Moderator
Don't mean to hijack (even though same topic).. I have an early 4L80E I am trying to mate to a LS1. I have the spacer but it looks like the bolt patern on the flex plate is 3 holes at 9 5/8" in a triangle and the verter has 6 holes at 10" in triangle.
Do the early / later 80E's have different bolt patern?
Or does it sound like I have the wrong flex plate?
TIA
Shaun
Old Jan 10, 2007 | 08:23 PM
ABeasst's Avatar
what year 4l80? I just picked up a 92 and need to know if it will mate up.
Old Jan 10, 2007 | 08:33 PM
LIL SS's Avatar
Moderator
I can't remember for sure but I know it's somewhere around a 92.. Maybe 91 or 93 but with i that range. I think I might have the wrong flex plate PN 12563136..
Old Jan 10, 2007 | 09:10 PM
i have no idea what year mine is... is there a way i can tell?
i really only know what i have found out for myself and posted here.. im not well versed on 4l80 history no way.
Old Jan 11, 2007 | 12:33 AM
LIL SS's Avatar
Moderator
Where are your bellhousing bolts? Do all of them, line up with the LS1 block? The early ones don't have a top bo;t. it's a little off to the passanger side.
Old Jan 18, 2007 | 05:34 PM
LIL SS's Avatar
Moderator
Carefull ordering 12580709 from pace. Ordered it and received 12602448 from them today. Not happy since I wanted to get the motor in tonight and work on the rest of the wiring..
Old Jan 19, 2007 | 03:41 PM
LIL SS's Avatar
Moderator
FYI.. Pace advised 12602448 is the replacement for PN 12580709.. However, there seems to have been a MFG'ing issue on the 12602448. All the ones Pace had in stock were not drilled with the correct number of holes and spacing from what Chuck has told me. He is getting a few new ones from GM hoping they are right.
Old Jan 26, 2007 | 10:47 PM
  #32
nitrorocket's Avatar
Mighty, there is no need at all to have more then 3 bolts. 3 bolts will hold 2000 hp.
Old Jan 26, 2007 | 11:08 PM
  #33
well im putting in 6 in case 4 get loose then
Old Feb 12, 2007 | 12:14 PM
  #34
my last update to this post.
tci ls1 flexplate, yank 4l80 converter
the 3 bolts yank supplies are too short for the tci flexplate
you need 20mm long. get grade 8 equivalent or better
the tci flexplate has 3 hole positions for ls1 and 3 for standard small block
the yank converter has 3 hole positions for ls1 and 3 for standard small block
i bought 6 bolts, and lined it up and just like JMBLOWNWS6 said, all 6 just go right in.
for 50 cents a bolt it is silly not to go ahead and put all 6 in.
i also ground the paint off of all the surfaces, inside and outside of the flexplate, and mounting surface of the converter.
yank masks over the converter holes but the entire foot needs to be paint free, as that is the mating surface.
tci may claim that they no longer paint their flywheels and use a grey coating etc... but there are plenty of new black flexplates in circulation as i just got one.
that is all
Old Feb 12, 2007 | 02:47 PM
  #35
NA$TY-TA's Avatar
So that means the Trans is in??? Pic's man pic's.... you know better then that....
Old Feb 12, 2007 | 02:56 PM
  #36
JMBLOWNWS6's Avatar
Im glad you got it all worked out bro! I am mad busy with a 402 T88 project and doing a 4l80 also in it. I will post the pics I took a long time ago so everyone can see it with six bolts. The pics suck but you can see it at least.
Old Feb 12, 2007 | 03:43 PM
  #37
JMBLOWNWS6's Avatar
TIA
Shaun
No they dont. Because thats what I am running.
  #38
JMBLOWNWS6's Avatar
Kyle you looking for a 4l80 now?
Old Feb 12, 2007 | 04:39 PM
  #39
NA$TY-TA's Avatar
O/D would be nice..... What do the older priced 4L80's run????
I see that Rossler is charging $1500 to beef one up... but thats w/o the TB... id liek a MVB also......
Its not to bad cruising now but it does have me interested.....
I wonder about my converter.......... hate to waste the $$$
Old Feb 12, 2007 | 05:37 PM
  #40
JMBLOWNWS6's Avatar
Yea I run around with the manual valve body and have my pressure switch in the tranny wired up so you cant lock it up only in 4th(od). It is nice and I must say it wasnt cheap. Im sure you can get a good price for what you have now and make the switch.
