which 4l80 flexplate?
Old Jan 2, 2007 | 02:18 PM
MIGHTYMOUSE's Avatar
Default which 4l80 flexplate?
my requirement is i want to make use of all 6 bolt holes to the converter
please also perscribe good bolts (flexplate to converter) from somewhere.
tci
http://speed-eng.com/store/product_i...oducts_id=7790
gm truck
http://paceperformance.com/index.asp...&ProdID=143748
meziere
http://www.byunspeed.com/product_inf...d738cbd5ed0493
how many teeth are supposed to be on these anyway?
Old Jan 2, 2007 | 03:25 PM
BirdofPreyBandit's Avatar
Not trying to hijack this thread but please tell me that picture of your car is photoshopped. If not, GOOD GOD ALL MIGHTY!!! Are you insane!!!!?
Old Jan 2, 2007 | 04:07 PM
SuperZ's Avatar
yes it is photoshopped.he duznt evan have that car anymore.
Are you not going to go with a TCI?
12secSS's Avatar
What trans are you going to use? Are you using a specific conversion converter? May I recommend the Meziere flexplate (FP319)? It has the LS1 (11.05" B.C.) and the SBC (10.75" B.C.) bolt pattern that many aftermarket 6-lug converters use. You can either use the stock sized M6 (IIRC) or 7/16" bolts (like TCI uses) from ARP. I would not go with a factory unit though (flexplate or hardware).
That is real, he had a long an extensive write up on here a couple of years ago. He had to make the nose and hood one piece.
Old Jan 2, 2007 | 04:38 PM
GregWS6&z28's Avatar
didnt your new Yank come with any converter bolts? I would stick with those. and run the TCI recommended flexplate.
Old Jan 2, 2007 | 05:05 PM
good point greg, it did come with bolts, but only 3.
i have a yank sc3000 for 4l80 and a 4l80 from transformance
i still have the car
*edit*
i heard the truck stock flexplate was just as strong as the tci but half the price
Old Jan 3, 2007 | 08:47 AM
just updated the list with the meziere.. why would anyone want this one? its soo expensive
Old Jan 3, 2007 | 09:09 AM
how come on this tci webpage it says 399753 (speed eng link) will not fit 4l80e, but speed eng. has them right there in the 4l80 kit?
http://www.tciauto.com/Products/Flywheels/
Old Jan 3, 2007 | 09:20 AM
12secSS's Avatar
The reason why I opted for the Meziere is because of the one piece billet design. Also having comfort knowing my driver's legs will not be sheared off if the flexplate fails. It is very light wieght as well, very close to the OE wieght, yet very strong. It is not made from stamped steel and ring ring (some are made overseas), but from a michined block of aluminum here in the USA. The michining ensures the better runout tolerances and tighter teeth tolerances for a more precise fit and functioning flexplate.
As for why the TCI is listed as not fitting the 4L80E, it probably has to do with the fact that 6.0L and 4L80E had a spacer for the flexplate and converter, plus the converter uses the old SBC pattern. Beyond that, I have no idea why they would listed as such. But it will fit.
Old Jan 3, 2007 | 11:58 AM
if you write or call Dave @ Yank I'm sure they will send you another 3 no problem.
Old Jan 4, 2007 | 09:12 AM
anybody else use a 4l80? what did you do?
Old Jan 4, 2007 | 01:56 PM
cablebandit's Avatar
i used the stock flywheel...98...my fuddle only has 3 bolts.
Old Jan 4, 2007 | 02:56 PM
Z'mnypit's Avatar
I used the stock here also. Only used 3 bolts with my Yank... Just out of curiousity what would it hurt if you drilled the other 3 holes?
Old Jan 4, 2007 | 05:27 PM
i dunno but i'll let someone else try that
Old Jan 5, 2007 | 01:28 PM
burbanman's Avatar
Dave, I used the TCI flexplate, Vig multidisc(5) converter with only 3 bolts also. Have had 1.3x 60's and 9.4's on 250shot of juice out of the hole, with no issues. Just use a good bit of RED locktight on the converter bolts, otherwise they can back out.
Old Jan 5, 2007 | 01:56 PM
TwnTrboCE's Avatar
TCI here. 3 bolts.
Old Jan 5, 2007 | 04:05 PM
well dang. that reply carries a lot of weight with it.
Old Jan 9, 2007 | 02:30 PM
i called tci about this. they said the flexplate does not have the 11.5" hole spacing for a stock 4l80 converter
it does have 3 holes for a 10.75 space of a std sbc and it has 3 holes at 11.00 for a 4l60 style converter.
so as long as my yank is at 10.75 or 11.00 it will be good. ill measure tonight
Old Jan 9, 2007 | 07:46 PM
SSHOTROD's Avatar
TCI, precison and 3bolts
Old Jan 10, 2007 | 10:56 AM
12secSS's Avatar
Just noticed this ... 168 teeth.
