4L60E leak
Old Jan 13, 2007 | 12:58 AM
jetlag's Avatar
Default 4L60E leak
Whenever I drive my car then park it, I can find some transmission fluid on the ground. It is coming from the front of the tranny...what could be leaking?
Old Jan 13, 2007 | 01:51 AM
Boodyrider's Avatar
Jack it up, put it on jackstands, take a nice bright flashlight and find out. Could be trans lines, could be a seal, could be a pan gasket. A good look will help more than my guess will.
Old Jan 13, 2007 | 01:59 AM
Figz Z28's Avatar
Check your cooler lines.
Old Jan 13, 2007 | 02:07 AM
jetlag's Avatar
This isn't mine, but it is a picture I found on here.
Mine is leaking around that round metal piece and on the front where it bolts to the engine. Definately red transmission fluid. Not a rear engine seal.
Old Jan 13, 2007 | 11:00 AM
performabuilt's Avatar
LS1Tech Sponsor
Well if its coming from there its going to be either the pump oring, pump seal, or one of the little orings on one or the pump bolts, But your going to have to pull it out to figure out in which case I would replace all of the above and be done with it,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 13, 2007 | 03:02 PM
jetlag's Avatar
Ugh, that makes me sad.
Old Jan 13, 2007 | 03:07 PM
LS1Tech Sponsor
Sorry
__________________
Call 888-744-6542
Old Jan 13, 2007 | 04:22 PM
01WS6er's Avatar
Take the little round plug out at the bottom as in the pic. If there is fluid in ther than get ready to pull the tranny out and replace all the seals as mentioned above.
When you remove the convertor make sure that it is smooth (where it goes in the frt pump) or it will ruin the new seal when you put it back in.
Old Jan 14, 2007 | 01:34 AM
jetlag's Avatar
How does it come up? Just pry on it with a screwdriver?
Old Jan 14, 2007 | 08:52 AM
Figz Z28's Avatar
Just pry it with a small screwdriver.
Old Jan 14, 2007 | 09:10 AM
WeeWolf's Avatar
how would you know you dont even work on your car
j/k Dave but yeah just pry on it with a screwdriver but if its leaking there get ready to pull the trans.
Old Jan 14, 2007 | 11:49 AM
Figz Z28's Avatar
I do when i got the time.
