Any F-Body with 4L80E?
would have to recommend the 4l80E tranny. This will work and hold up to all the power you want to put to it. Then you will need the TCOM computer to operate it. The # for the tranny is 271000 and through us it is 2550$ and the controller is 860$. Hope this helps and thanks .
I reply them a few questions but still waiting(To long reply times...but at least they send a answer )
Anybody haves any ideas on the sujeckt? Or will it work on my 98Z28 A4? I dont want to buy all the thinks and import here to find out ohh its not working..... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Thanks in advance
Btw:I never saw or hear a LS1 f-body with that set-up thats why....
They sell there's with the wiring harness, computer and everything you need to mate it with a stock LS1. However, it's better to keep your stock computer and send it to Ed Wright for programming, that's who they use. I think, if memory serves, it was $2500 with a core exchange. A TH-400 core. Check with them to make sure, it's been awhile.
I chose to give the FLP level IV a shot. If it blows, I'm getting the 4L80E.
Good luck.
So the size of the 4L80E is the only draw back ?Its not a problem for me <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I can cut everythink under the car(if neccesary)but i bealive a little hamering and a custom dirveshaft solve the problem.
I ll send a e-mail to Hughes asap!
Thanks!
1) It weighs a ton - you will definitely pick up weight with the switch
2) It has substantially more parasitic power losses than other auto trannies available
It will be bulletproof, but it is going to slow you down over other choices.
There are other transmissions out there that can be built to take *big* torque without some of these side effects, but usually you have to fork out the $$ to do it.
T-56?
TH350?
TH400?
4L60E?
4L80E?
PowerGlide?
Anyone...
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
I would personally like to know the T-56 and the TH400 weights... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I am familiar with the manual valve bodys.I have a TH400 with a manual valve body+trans brake on my 69 Camaro BB.But anyway its a valubale information.So i only need Ed to tune my computer(After the trany+swap parts) <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
WeatherGuy: Yea i know the cons <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> But after all i have to buy a great trany that holds on the top speeds.Btw: (Not 100/100 sure) but i am planing to build a twin turbo LS1 in this winter.(or a LS1 motorsports single turbo with a build bottom end stock cube or 6.0 liter cast block based Ls1)
The 4L60E can be built to hold up for a while behind 450+hp but, reliability is still an issue. Hard parts are finally being developed for this trans. which may put an end to the reliability concern in the future. The nice thing is it is a direct swap and is actually one of the cheaper routes as no other fab/fitting work is necessary.
The 200-R4 can be built very strong, is actually lighter than the 4L60E, and has the same overdrive. The only con I can see is $$$.
You could do a T-350/400 but, then you have to get a gear vendors overdrive which is big $$$.
Each setup has advantages/disadvantages. Makes it hard to decide. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
John
<strong>how much more weight are we talking with the 4L80E?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">~90#'s according to GM.
Check here for info on these transmissions.
http://www.gm.com/automotive/gmpower...apps/index.htm
John
<small>[ August 22, 2002, 09:42 PM: Message edited by: XLR8NSS ]</small>
<strong> WeatherGuy: Yea i know the cons <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> But after all i have to buy a great trany that holds on the top speeds.Btw: (Not 100/100 sure) but i am planing to build a twin turbo LS1 in this winter.(or a LS1 motorsports single turbo with a build bottom end stock cube or 6.0 liter cast block based Ls1)</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">OK - just be *really* ready for these issues if you go ahead with a 4L80E. If money is not an issue, I would recommend another tranny. Alternatively, you could run the ghetto route and get a TH350/400 and drive around without an overdrive. Lots of things to weigh here.
<strong>I was thinking about a 4L80E since it is strong and has overdrive but, it weighs alot, requires clearancing, and the overdrive is only like .9:1(hardly worth it)</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">just for informative purposes here are the tranny gear ratios....
Transmission Ratios
Turbo 350 (1st)2.52 (2nd)1.52 (3rd)1 (4th/OD)N/A
Turbo 400 (1st)2.48 (2nd)1.48 (3rd)1 (4th/OD)N/A
2004R (1st)2.74 (2nd)1.57 (3rd)1 (4th/OD)0.67
700R4/4L60E (1st)3.06 (2nd)1.63 (3rd)1 (4th/OD)0.7
4L80E (1st)2.48 (2nd)1.48 (3rd)1 (4th/OD)0.75
optional (1st)2.75 (2nd)1.57 (3rd)1 (4th/OD)0.75
I chose to go with the optional gearing (2.75 1st and 1.57 2nd) for the 4L80E that way its gear ratios are closer to the 4L60E that Im replacing
<strong>well weight aside (i dont think 90 lbs. is too bad) what do you mean weatherguy when you say more parasitic power losses?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What he means is that it will take more power to "turn" the tranny and you wont get as much to the rear wheels....for example lets say with a 4L60E you make 415 RWHP you will make a little less with the 4L80E...say 400 RWHP. Now im not exactly sure how power is lost but im pretty sure its minimal. I would trade 15 HP for peace of mind knowing that my tranny will handle the power and not be worrying when the 4L60E is gonna take a dump on me.
<strong>Shoot me some info on this trans. please. Thanks <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You got mail <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I just got my 4L60E rebuild to handle 850 rwhp and 900 rwtq.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I hate to be candid, but I call bullshit. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I've never seen a 4L60E last at levels over 650rwtq for more than a few passes.
<strong>Who built that for you? That's the most I've heard any shop say one of these transmissions will hold.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">yea who built it?? post on here so everyone knows
I hear that cores can be $2500.
I'm not sure on weight but if you were pushing like 1000-1400 HP I doubt you would care. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
