Car wants to go forward...in park?
Old Jan 25, 2007 | 05:05 PM
UnitZ28's Avatar
Default Car wants to go forward...in park?
I have just rebuilt my engine, its a 383 503 cam and a madz tune, the trans is stock and is out of a cop caprice with the stock stall conv with about 70k miles on it why would my car be wanting to go fwd in all gears? the shift linkage feels all wrong but i can tell its in park.. is something wrong with the valve body? or the operator? or somethin else? car is a 94 camaro thank you for your help in advance
Old Jan 25, 2007 | 05:24 PM
Montec's Avatar
Sounds like you linkage is f'd up, and your not actually in park. Also, say buh bye to that trans pretty soon.
Old Jan 25, 2007 | 07:04 PM
UnitZ28's Avatar
yeah i know that... if i had the green it would get a 6 spd.... but I took all the linkage off and made sure the gear selector was in PARK.... still moves forward
Old Jan 25, 2007 | 07:18 PM
performabuilt's Avatar
LS1Tech Sponsor
You may have damaged the shift rod if the trans is not in park with the assembly rotated all the way clockwise you will need to pull the pan and take a look I have seen them twisted and broken
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 25, 2007 | 07:30 PM
UnitZ28's Avatar
doh! i'll pull it off and see if i messed anything up.... is there anything else that would cause this?
Old Jan 25, 2007 | 07:36 PM
LS1Tech Sponsor
no pretty much thats about all it could be park is a purely mechanical function
__________________
Call 888-744-6542
Old Jan 25, 2007 | 07:47 PM
chris718's Avatar
do you have reverse?does it stay put or roll when pushed in park?if these are ok i would suspect the forward clutch is burnt and stuck to the forward hub thereby trying to drive the front sun gear and planet causing the pulling forward
Old Jan 27, 2007 | 06:52 PM
UnitZ28's Avatar
sry guys im retarded nothing was wrong, i was in 1st instead of park
Old Jan 27, 2007 | 07:28 PM
LS1Tech Sponsor
we all have those moments in life lol
__________________
Call 888-744-6542
