Do i need a trans tune with a ss4000?
Old Feb 25, 2007 | 10:54 AM
dameter21's Avatar
Default Do i need a trans tune with a ss4000?
I was thinking about getting a ss4000 stall instaled, but how imporTANT is the trans tune with this size? 2000 T/A, a4, lid, catback,
Old Feb 25, 2007 | 02:43 PM
DrkPhx's Avatar
I'm sure some will chime in and say no, but the reality is yes you will. The main reason is to prevent random locking and unlocking of the converter. The next is to maximize the driveability for part throttle driving around town.
Increasing shift speed is recommended as well to help tighten up the the loose shifts that come with a big stall.
Old Feb 25, 2007 | 03:24 PM
Roarin_8's Avatar
Get it tuned, it should only be around 120 dollars for it. I believe that anything over a 3400 stall needs to be tuned.
Old Feb 25, 2007 | 07:11 PM
AK's WS6's Avatar
My SS3800 isn't bad at all un-tuned. I'll get it tuned after I install some LT's but untill then it will stay the way it is.
Old Feb 25, 2007 | 07:17 PM
presto_z's Avatar
tune it for sure.. get that lockup speed right where u want it.. along with some firmer shifts and change in shift points and kickdown
Old Feb 25, 2007 | 09:54 PM
HUNTER02SS's Avatar
You also want to make sure that you get the "TorqueManagment" turned off as well!!
Old Feb 26, 2007 | 12:41 AM
WhiteStripes's Avatar
Seriously, as long as you're doing that, have them throw in the TransGo shift kit, I've seen it for as cheap as $110.00, and it'll help tons. After that stick a bigas cam in there like an MS3 or similar and that thing will be a street beast!
Old Feb 26, 2007 | 01:42 AM
Outlaw LS1's Avatar
Im pretty sure it wont shift 2-3 WOT without the tune.
Old Feb 26, 2007 | 07:10 AM
FLT's Avatar
FLT
I have also heard of them killing the motor in reverse. The idle speed will have to be adjusted.
Old Feb 26, 2007 | 02:23 PM
Roarin_8's Avatar
And in drive too, mines did that twice after I had it put in and tuned. No problems after the cam since it's at 950rpms at idle now.
Old Feb 26, 2007 | 06:10 PM
99Hawk262's Avatar
I drove my SS4000 for a couple weeks untuned....no issues at all. And yes, it will most certainly shift 2-3 at WOT. However, it drives much better tuned. Raising the idle speed is a must since it will surge at idle. You'll be okay but tuning should be on your list of things to do ASAP.
Old Feb 26, 2007 | 08:46 PM
Outlaw LS1's Avatar
I wouldnt say certainly considering im the third person i know who had to get their tranny tuned to shift 2-3 WOT after putting in a 3200 or higher stall.
