People with stalls, are you using a shift kit?
Old Apr 3, 2007 | 03:05 PM
chrs1313's Avatar
no shift kit here either...
Old Apr 3, 2007 | 05:35 PM
DRIVER456's Avatar
Not trying to steal this thread,But since your on the subject of shift kits.I have a shift kit in mine,But the 1-2 shift is brutal at low speeds.I have the 2 heavy springs and 2 washers in the accumulater.I took out the 2 washers and it still shifts kind of hard.Should I change both springs with softer ones or just change one spring thats in the accumulater..................Paul
Old Apr 3, 2007 | 06:11 PM
performabuilt's Avatar
LS1Tech Sponsor
Personally other than changing to the updated accum piston we leave the 1-2 accum stock in all three levels of our units and that will give you the shift you desire. Progressive
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 5, 2007 | 04:19 PM
AK's WS6's Avatar
PBA's "modded" kit here, setup per his specs (1 washer and some larger feed holes) and it is great under normal driving and at WOT, I love it!!
