3200 vig/3:73/a4
Old 04-04-2007, 09:41 PM
jt121212's Avatar
Default 3200 vig/3:73/a4
i dont think its going into overdrive ..115 at 6200//just wondering what the mph should be at the top of fourth at 6200 rpms???
Old 04-05-2007, 12:38 AM
Casey2323's Avatar
Default ummm
I dont really want to awnser this but... you didnt list tire size .. if your wot i am sure its not going into lockup.. and there is no way in hell your still in third gear with 3:73 gears... but i have no idea on your mph...
Old 04-05-2007, 12:51 AM
LS1Tech Sponsor
performabuilt's Avatar
115 at 6200 rpm 373 sounds like third gear , . But note 1 most 4l60e trans can not do a FT OD unless reprogramed in the PCM to do so , And lockup is never allowed unless programed in at FT
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-05-2007, 12:52 AM
germeezy1's Avatar
So will it shift?
Old 04-05-2007, 12:58 AM
LS1Tech Sponsor
Unless the PCM is programed to allow it no , The trans can only do what the PCM tells it to and nothing more.
__________________
Call 888-744-6542
Old 04-05-2007, 01:24 AM
germeezy1's Avatar
So is that his top speed then?
Old 04-05-2007, 01:36 AM
LS1Tech Sponsor
Well it may be his top speed in 3rd but if hes not shifting to fourth because of programing then if he fixes that his top speed would be 30 pecent higher approx 150 mph
__________________
Call 888-744-6542
Old 04-05-2007, 01:56 AM
germeezy1's Avatar
Isn't a WOT shift into 4th bad for the transmission?
Old 04-05-2007, 08:02 PM
sixvi6-camaro's Avatar
Yup.. From what I've read 3-4 WOT is a bad thing unless the trans is built for it..
https://ls1tech.com/forums/automatic-transmission/607389-question-pro-builders.html
Old 04-05-2007, 08:36 PM
jt121212's Avatar
the builder that built the trans sent me a new valve body, i changed it out today and it working great now!!! at 55 mph it running about 2100 and wot shifts great.something must have been sticking.
