Please Help 3600 Stall Do I Need To Do Anything Else Besides Put It On
hello I Will Be Installing A 3600 Stall In My 98 Ls1 Z28 Auto I Was Wondering Do I Need To Do Anything Besides Put It On What Else Do I Need To Do After I Put A Stall On Do I Need To Do Anything With The Computer Or No And Also What Kind Of Time Gains Can I See From This Stall Please Help Since I Will Put It On This Week And I Want To Take It To The Track This Weekend.
A cooler is a great idea of course and some cars require some tuning to get the shiftpoints right and or if the 7xx codes come up.
__________________
thanks it already has a depper oil pan and i think it has a shift kit so i guess play around with the shift points and put a tranny cooler and also what are the 7xx codes do i need to worry about those
I perfer a Tranny cooler, shift kit and trans tune to be done when adding a 3000+ stall converter.
You might need a new tranny shortly after that many times if you don't do the cooler.
Nope, i ran a 3000 tci last season with just sticky tires and ran into the twelves. so this year i swapped in a 3600 from fuddle. If you are doing a stall only you'll be just fine. Assuming your not swapping gears, then you will want some tuning. But you wont have any problems with the 3600, just get some sticky tires for racing.
