whats the difference between ......
Old May 31, 2007 | 09:37 PM
ls1blazer's Avatar
Default whats the difference between ......
a ls1 4l60e and a 5.3l truck 4l60e?
Old May 31, 2007 | 09:41 PM
fastlane02's Avatar
i believe the tailshaft is the only diffence but someone can correst me if i'm wrong
Old May 31, 2007 | 09:49 PM
performabuilt's Avatar
LS1Tech Sponsor
Theres is no difference unless its a 4x4 different outout shaft link, the 2wd tail housing is diferent and in some caes the bell but those can be swapped
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 2, 2007 | 10:01 AM
ls1blazer's Avatar
what about the servos?
Old Jun 2, 2007 | 10:03 AM
LS1Tech Sponsor
the camaro will have a corvette servo and the truck may not That I would check and if the truck does not swap it over, You will have to look though because I have see trucks with and without the corvette servo. I am not sure if they were swapped or came that way though.
__________________
Call 888-744-6542
Old Jun 2, 2007 | 03:10 PM
BlackHawk T/A's Avatar
It probably depends on the year I would guess.
Old Jun 2, 2007 | 04:23 PM
sroach20's Avatar
i had to swap the shifter linkage over when i swapped an fbody tranny into my truck.
Old Jun 2, 2007 | 05:13 PM
ls1blazer's Avatar
The price between the two used is $400. Thats why Im asking. Thanks.
Old Jun 2, 2007 | 05:40 PM
LS1Tech Sponsor
Yes that is one thing the linkage shaft is short on the fbody and its long on the trucks to work with the PRNDL switch.Easy swap over though .
__________________
Call 888-744-6542
Old Jun 3, 2007 | 03:50 PM
ls1blazer's Avatar
I thought the gearing may be different. Would a converter from a ls1 car work on the truck 4l60e?
Old Jun 3, 2007 | 03:54 PM
sroach20's Avatar
insides are the same, yes converter wouod work.
Old Jun 3, 2007 | 04:05 PM
FLT's Avatar
FLT
The unit that you are looking at might be a 4l65e. This might be why it is $400 more. If it has an ID tag with a Z in the 3rd digit then it is a 65. An example would be 4KZD. Hope this helps. Vince
