4l60e Help Please
I topped it off and put it into the different gears. Axle off the ground.
Doesn't move forward/revers. It does however lung forward a bit when I start it. It also doesn't rev up in park. It revs as if I was doing a brake stand.
Any thoughts of what I did or didn't do?
I did do the sk4l60e shift kit, .490 boost valve with spring, vette servo, 9 pack 3/4 clutches, Kevlar band...
Any thoughts would be great.
Thanks for the help guys, I really do appreciate it as its been a battle ever since I started this project.
And what about the 3 bolts that hold the gasket and that plate are those 8ft lbs too???
I will take a look at it tonight and will let you know what I find out. Good thing I got 3 cases to atf...
Park, still revs like its in drive with the brakes on
Reverse, the tires kick back but nothing.
Neutral, Spins like mad forward
Drive, see above.
Axle is on Jack stands.
So I should probly change my valve body and plate? Or is it something internal that could cause this?
Do you think I should waste my time changin the vavle body out? I was gonna look at the gaskets just to make sure I used the right one. I had 2 choices and I matched the valve body to the picture. Maybe I am that lucky one where they used the other gasket and I chose the wrong one... that would be my luck.
I am so just gonna spend the money and pay someone else to build my next one.
The truck that its going was 250 bucks so uh I would have a hard time putting a billy bad boy tranny like yours into my lil pickup. I really do appreciate your help tho.
