What Rpm Are You At Going 80 Mph?
I just replaced my tranny and I think I have a higher stall torque converter I am revving at 2600 at 80 mph when I think I was at like 2300 or so before. I think the tranny came from a truck or something. Do they have higher stall converters in them?
I would not as long as lockup was working . Nor can the trans.
Originally Posted by cals400ex
i didn't know the stall would change the rpms at cruising speed
__________________
If your rearend gears stayed the same and your trans is a 4l60e, your cruise rpm will remain the same unless your lockup is not functioning. I'd assume you're either not in overdrive or your converter isn't locking.
Originally Posted by silver-mod-o
worse gas mileage, higher trans temps
Originally Posted by AutomagicLS1
My yank pt4000 does not lock and its a very loose converter. On the highway accelerating at 80 mph its turning just under 3K about 2800. The temps do rise on the highway with 2 big coolers im about 190 and it takes awhile for it to get up there. Honestly If my temps are low enough now to not burn somthing up im not really worried about lockup. im so used to it its not my daily driver so.
but if someone does daily drive that size converter. You will want lockup... for mileage if nothing else. You can cool anything with enough/big enough coolers...
