Tricky Question: Stall and zex kit
Old Jun 13, 2007 | 12:31 PM
1fastz's Avatar
Default Tricky Question: Stall and zex kit
I just recently purchased a zex nitrous kit and i was planning on using it at the track. The kit is a self activating nitous system and all you have to do it enable it through a switch that you turn on/off. The kit claims that it comes on at WOT everytime by working with the TPS wires, so theres no need to push a button to spray, it sprays on its own. My concern is that i have a tci 3500 stall and if im at the tree lined up and i flip the switch and then i stall up at 3000rpm, does that mean that the system is continuallly shooting nitrous as i just sit there and stall up?.... if thats the case, should i just activate it after the luanch?
Old Jun 13, 2007 | 12:34 PM
Predator T/A's Avatar
uh the kit shouldnt activate until you are at wot...are you running a 2 step or msomething lol
Old Jun 13, 2007 | 12:40 PM
1fastz's Avatar
no, im just running the regular old system. I thought at 3000rpm it is considered the begining of WOT and since i stall up to 3000-3200rpm before the luanch, i was thinking that the nitrous would be shooting already as i stall
Old Jun 13, 2007 | 12:45 PM
performabuilt's Avatar
LS1Tech Sponsor
I would gues its a system set up to come one using the TPS as the button , With a separate switch for the enable/disable Yes you would want to leave it off during the burn out
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 13, 2007 | 12:50 PM
1fastz's Avatar
oh yea, ill defenitly not switch it on during a burn out, but during the stall above 3000rpm?.... Im just wondering whats considered WOT and if it will be shooting nitrous while i stalll up at 3000rpm before the luanch since it activates at WOT
Old Jun 13, 2007 | 12:55 PM
LS1Tech Sponsor
WOT is when the TPS says the throttle blades are wide open , Or you have the gas bottomed to the floor , Anytime that happens and its enabled it will spray
__________________
Call 888-744-6542
Old Jun 13, 2007 | 03:50 PM
SSmoken's Avatar
i have a microswitch that activates mine. It starts spraying whenever the pedal is to the floor.
Old Jun 13, 2007 | 06:22 PM
aaron653's Avatar
well WOT stands for wide open throttle...so i would think it means just that
Old Jun 13, 2007 | 06:35 PM
1LoudTA's Avatar
the pedal has to be to the floor in order for it to read 100% throttle. now you should have a window switch that will only allow it to run between certain rpms.. like 3000-6xxx, a little bit under whatever your rev limiter is at. no matter what though it will only spray if the pedal is to the floor.
Old Jun 13, 2007 | 06:38 PM
Gilbert@Ace Racing's Avatar
I know for sure that there is a calibration feature on a ZEX system that determines WOT. After installation you will need to go through a calibration set up command and then take the throttle to WOT.
What I am not sure about is if there is a threshold of say 95% that enables the system.
Been there, done that on the test mule next door at Xtreme Horsepower. We utilized a ZEX 150 shot system for a while on that car.
Let me know if you need help... I will forward your questions to those guys for you!
g
