4l60E Wont Move!
Old Jul 11, 2007 | 03:55 PM
candyblueta's Avatar
Default 4l60E Wont Move!
My old transmission in my 98 trans am went, so i replaced it with a new one, and everythings back together, but now when i put it into drive the lever pulls back on the trans. but it doesnt move, no rpm drop or nything.....
All connections are plugged in!
HELP!!!
Old Jul 11, 2007 | 03:58 PM
Gilbert@Ace Racing's Avatar
Hmmm.... how much fluid is in it?
g
Old Jul 11, 2007 | 04:13 PM
Predator T/A's Avatar
you may have a broken pump or the manual shaft linkage is not connected pull off cooler line and start th car up see if fluid pumps out
Old Jul 11, 2007 | 04:21 PM
performabuilt's Avatar
LS1Tech Sponsor
Yes provided you have enough fluild in it the first thing to do would be to unhook a line and start car , If nothing comes out the most comon issue is you didnt have the converter fully seated and broke the pump. Its a common installation mistake
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 11, 2007 | 05:01 PM
wouldnt it go into gear tho? its not going into a gear. the rpms dont even drop.
Old Jul 11, 2007 | 05:02 PM
its as if its in neutral
Old Jul 11, 2007 | 06:18 PM
No... if the pump was broken it would not supply the necessary pressure required to engage the clutch packs!
And checking the linkage is a good idea, but if it's a fresly rebuilt or new unit that should not be the issue.
g
Old Jul 11, 2007 | 06:20 PM
LS1Tech Sponsor
If the pump is broken it will not do anything at all just like its in neutral. Have you removed a line yet and started it to verify?
__________________
Call 888-744-6542
Old Jul 11, 2007 | 07:10 PM
i removed the line that goes to the pper part of the radiator and no fluid came out when started........
Old Jul 11, 2007 | 07:35 PM
LS1Tech Sponsor
pump is broken sorry
__________________
Call 888-744-6542
Old Jul 11, 2007 | 09:07 PM
jay_99z's Avatar
Ahhh memories. That was my first converter install. I learned a lot that day.
Old Jul 11, 2007 | 09:10 PM
redvet99's Avatar
How much fluid did you put in it?
A new rebuild uses like 3 gallons. thats 12 quarts
Just check how much you put in......
Also, did you put a quart in the converter before you put that in?
Did you turn and push in on the converter and are you sure you felt three clunks as stator, input shaft and pump became seated one by one?
You may still have a chance........
Check that fluid first...if you put in somewhere near three gallons already then I'm afraid I agree with Performabuilt
Old Jul 12, 2007 | 12:45 PM
yes i put enough in... i guess its a broken pump. What does that entail to replace??? How much?
Old Jul 12, 2007 | 02:46 PM
redvet99's Avatar
Other than taking it out of the vehicle, if you rebuild the pump it will only cost you $50 possibly in parts and since its the first thing you remove from the tranny other than the pan, it's not that bad. However, I don't want to mislead you though, I've been wrenching for the past 28 years as a hobby
You may find this too difficult.
If you ship it back to who built it, I would figure a ballpark guess excluding freight would be somewhere in the neighborhood of $300-$400 for parts + labor.....
The professional tranny guys out there can chew me up any time they want now
Old Jul 12, 2007 | 02:54 PM
LS1Tech Sponsor
Not going to chew at all. It wont be real cheap however its done . But a person with moderate mechanical skils and some guidance should be able to change a complete pump . Generally with our customers unless they just want to send it back thats what we do just sell them a pump then walk them through changing it and checking to make sure the converter is undamaged. So far so good it has happened a few times. Its probably close to if not the most common installation mistake.
__________________
Call 888-744-6542
Old Jul 12, 2007 | 06:06 PM
ohsofast's Avatar
That happened to me about 5 years ago. I broke the pump but didn't know so I had the car towed to a trans shop and it cost me a little over 600 dollars. Life lesson is what that was. That hasn't happened again.
Old Jul 14, 2007 | 03:46 AM
the guy i bought the transmission from is going to replace it for fee, including un-install and install! Thats badass customer service!!!
