Question about Vigilante and nos!
Old Jul 15, 2007 | 02:05 PM
NONOS's Avatar
Default Question about Vigilante and nos!
I have a ls1 with bolt ons! I have a 4000 vigilante stall in my car! I want to spray a 150 shot of nos! Alot of people say it won't work that a yank 3600 will be better? They say the 4000 vigilante has no anti ballooning plates! Will this work or not! Thanks for all your help!
Old Jul 16, 2007 | 04:02 AM
james562's Avatar
I would love to know as well!!! I posted something very similar in another thread
https://ls1tech.com/forums/automatic-transmission/748871-whos-gone-3200-vig-3600-vig-vice-versa-why-results-n2o-users.html
Seems like the vigs don't get any love for N2O around here
Maybe Vince or Performabuilt can chime in on this?
Old Jul 16, 2007 | 04:28 AM
AutomagicLS1's Avatar
I told you over and over you would blow through that vigilante but you never listen. Id go with any of the yank SS converters probably a 3500 or somthing maybe 3000. It wont hit/pull anything up top like your loose vigilante did on the motor b/c its alot tighter converter but you wont blow through the converter on the spray
Old Jul 16, 2007 | 05:17 AM
FLT's Avatar
FLT
I personally feel that a 4000 stall is way to high for what you are trying to do with it. I normally suggest a 3200-3600 and I personally prefer the 3200. I do believe that Vig does come with the ballooning plate. Give PI a call to verify this and if you bought your converter new get it restalled. No offence against Yank but I have had much better luck with the Vig in my units. I have had a couple lockup clutch issues with others recently but not in the Vig. Just my opinion from what I have seen first hand lately. Maybe they got a bad batch of clutch linings. I don't know. Vince
Old Jul 16, 2007 | 07:07 AM
Ed Blown Vert's Avatar
So far my Vig 3200 works fine with FI and Nitrous.
Old Jul 16, 2007 | 07:15 AM
PBA's Avatar
PBA
The Vigilante comes with the anti ballooning plate. As far as the NOS, I agree with Vince the lower stall 3,200rpm will work better. I have been a distributor for PI industries for about 9 years, and have only had a few complaints in all those years, so I would highly recommend them.
Old Jul 16, 2007 | 01:18 PM
james562's Avatar
PBA so I will be fine with the 3600 Vig on spray?
Old Feb 23, 2008 | 08:07 PM
C_Rules's Avatar
im curious a lower stall is better on the spray? a 3200 is better than a 3600 if you're going to spray?
Old Feb 23, 2008 | 08:14 PM
02 BLK WS6's Avatar
Vig converters have a billet front cover.
Old Feb 23, 2008 | 08:49 PM
C_Rules's Avatar
and yank does too. but is a lower stall better for nitrous?
Old Feb 23, 2008 | 09:45 PM
c0ncEpT's Avatar
The vig's usually flash higher than they are advertised, So your 4000 stall might flash to 4300 NA which would make it flash super high with N20. I agree with everyone here that it will blow threw. If you don't want to make any sacrifice NA you could go with a yank SS4000 converter which will take a 150 shot all day long and still be efficient.
Old Feb 23, 2008 | 11:12 PM
C_Rules's Avatar
what does blow threw mean?
