Which tranny cooler and where to put it?
Old Jul 29, 2007 | 09:06 PM
98Camarod's Avatar
Default Which tranny cooler and where to put it?
I have a 4000 Fuddle on the way and I'm in the middle of doing a heads/cam swap due to a collapsed lifter. I've got to order a tranny cooler and I was just wondering which one you guys are running and where did you put it?
Old Jul 29, 2007 | 10:36 PM
Figz Z28's Avatar
B&M Transmission Cooler, 24000
Old Jul 29, 2007 | 10:37 PM
98Camarod's Avatar
Location?
Old Jul 29, 2007 | 10:57 PM
Travis99LS1's Avatar
i have my'n in front of the condenser at the bottom...
Old Jul 30, 2007 | 12:00 AM
transaman98's Avatar
hopefully this helps.
Old Jul 30, 2007 | 12:10 AM
98Camarod's Avatar
Do they come with the mounting hardware or are you on your own with it?
Old Jul 30, 2007 | 12:26 AM
98turbls1's Avatar
I mounted mine parallel with my ac condensor... i'm about to pull my ac off anyways so it does matter if it blocks the condensor..
Old Jul 30, 2007 | 07:32 PM
Air can pass thru the trans-cooler..so if you put it in front of the condenser or radiator your not blocking any flow from either one.
Old Jul 30, 2007 | 07:40 PM
5_02ls1's Avatar
i got a tci 30,000 gvw cooler from jegs and it mounts in front of the ac condenser i dont have ac anymore so mine is mounted to the radiator...yes they do come with mounting hardware
Old Jul 30, 2007 | 07:51 PM
redvet99's Avatar
B&M Supercooler
In front of the A/C Condenser
I'm running in the 180s at 90F in traffic
Also have a Dewitt's radiator.....it runs in the 180's too.
And this is with the air on!
This is on my 95 383 Corvette Coupe Stroker
Old Jul 30, 2007 | 07:56 PM
waterbug1999's Avatar
I think mounting it TO the radiator is a bad idea.. The radiator will cause it to heat up to the radiator temp.. I just zipp tied mine in front, off the radiator.
There is mouting it "dope" style up front.. Maybe a search can find you pics on it.
Old Jul 30, 2007 | 08:31 PM
98Camarod's Avatar
^^^^Search....thats a good one. We are still waiting for that. I will probably mount it the way the one pictured is.
Old Jul 30, 2007 | 08:41 PM
I dont think that one is the B&M 24,000 though...
Old Jul 30, 2007 | 08:48 PM
My90Iroc's Avatar
What lines/fittings are you guys using?
Where are you getting them from?
Old Jul 30, 2007 | 08:51 PM
My B&M cooler, all the parts came with it. Actually, its a univeral kit, just use the parts needed for the install.
Old Jul 30, 2007 | 08:54 PM
Phoenix 5.7's Avatar
if u get the B&M, throw the hose that comes with it in the trash and get some good hose from a parts store. the b&m hose is absolute crap.
Old Jul 30, 2007 | 08:56 PM
Been on the car for 3 years, no problem what so ever.
Old Jul 30, 2007 | 09:01 PM
i couldn't get mine to not leak at the cooler.
