electronic transmission problems help
Old Aug 9, 2007 | 07:02 AM
1sick-Z's Avatar
Default electronic transmission problems help
i have a built 4l60 e in my 94 and it wont shift into 3rd gear at any rpm it just feels like neutral im doubting if there is anything mechanicaly wrong with the trans because i changed the fluid and it was bright red no metal flakes or anything, and seeing how it has only been in it 4 a month with stock tires so im thinking something electrical in the trans like a servo or something for 3rd gear is messed up let me know what u think thanks
Old Aug 9, 2007 | 07:38 AM
performabuilt's Avatar
LS1Tech Sponsor
Well if it feels like 1-2-neutral then the 2-3 shift is being comanded so it is more then likley a mechanical failure. With no debris the most common thing is the snap ring broke or came out of the 3-4 clutch.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 10, 2007 | 05:36 AM
ttcamaro's Avatar
i had a similar problem and it was electical. My car would feel the same way goes into neutral with shifting to 3rd. It was just in the wiring. After i fixed that worked like a charm
Old Aug 10, 2007 | 07:29 AM
FLT's Avatar
FLT
You should contact the builder of your transmission. A 3-4 clutch failure in that little bit of time is very disapointing. Hopefully they will help you out. Vince
Old Aug 12, 2007 | 06:48 PM
1sick-Z's Avatar
What did you find in the wiring???? I hope that is my problem too.........
Thanks!
Old Aug 13, 2007 | 11:07 PM
millerpa's Avatar
Im A Newby to the V8 world. Love It! Just got A LS swap and a Built 4L60E In My old 2001 V6. Having the same problem with tranny, Replaced both shift silinoids cuz had them around. Thinking 3-4 clutches now. so how do i make sure with out wasting money on the wrong parts. 1st and 2nd shift normal, shifts to 3rd and nothing
Old Sep 4, 2007 | 12:42 PM
1sick-Z's Avatar
I have been in contact with them and they have been very helpful so far. I am awaiting the replacement...and will let you know what they find.
Old Sep 4, 2007 | 05:36 PM
DrumrReagh13's Avatar
Mine is similar too. But it only does it sometimes going into 4th (overdrive). Ive been racking my brain with this and I really wanna know whats goin on with it. Its the factory tranny and its a 2001 T/A.and it only seems to do it on the interstate. Any help is appreciated!!
