Yank Fuddle Vigilante
#42
i had a fuddle 3200 in my vette and it worked good. when i went to a 3600 i switched to a yank. nothing bad to say about my fuddle performance 3200. it performed great for me. i ran the 3200 with 3.15 gears and the 3600 with 3.42 gears and only dropped from 11.8 to 11.7. i believe it will get a bit better with better traction but nevertheless the fuddle was definitely good.
#44
ive got an FTI in my third gen 4000 stall my dad had a chevelle with a yank and after 2 came apart in less then 500 miles they built the third that was 4200 stall that had to turn 2500 to back out of the driveway. look into FTI they have a forth gen running 9.19 with a 4l60e. daily driven.
#47
Originally Posted by PBA
"Only dropped 150 rpm on the shifts." I have never seen one with so much slip, and Mike calls this a "shift extension"....... another euphemism for "slip"....
I gained an assload of MPH by going with a Yank PT4000 over my old Vigi 3200 and the car is a completely different beast.
#48
Originally Posted by ponyeater01LS1
Dont let me get started on Fuddle. John at Fuddle you guys keep up the good work awsome job mine is almost 2 yrs old driven from NC to minnesota 4 times and still to this day runs low 12's and 170 60 ft times period end of story. YANK AND VIG IS JUST A NAME U ARE PAYING FOR GET OVER IT. Its just like shoes everyone thinks nime is the shizzle but guess what sunshine newbalance makes the same sh@t only cheaper. ok I'm done now
#50
Originally Posted by TA1364
For the price fuddle seems good, only thing that concerns me would be DD. I would want the tighest converter possible cause it would drive me insane listening to high rpms all the time driving around the city. I really need to ride in a stalled car
thats the best way, probably the only way to find out what you can tolerate as far as DD goes... get into a stalled car and see how it rides.
things that will help make it feel "less loose" are higher gears to get the car moving quicker, and i think the higher the STR the tighter the converter...
FWIW I will probably be running a fuddle coverter in the next couple days, unless i find a good deal on a PT4000... i'm told it is actually more close to a 4400 stall which is what i want.
