20mph roll downshift
Old Sep 13, 2007 | 09:49 PM
Dragkid1917's Avatar
Default 20mph roll downshift
When im rolling at like 15 or 20 mph, and whack the pedal, it goes for like a full second in 3rd or 4th gear, and then shifts down into first. If i go from 10 and slowley climb up to 20 it down shifts immediatly. It has to do with the converter im sure, i think when its sitting at 20 it revs up untill it hits the stall speed in the big gear and then down shifts. How do i get it so when i whack the pedal at any speed under 45 (pretty much my 1st gear redline) it immediatly shifts down. If i were to race from a roll idk what i would do because it stays in the high gear and goes to like 3500 and then shifts down.
Old Sep 13, 2007 | 10:00 PM
DSRCAM's Avatar
id ask ur tuner to check it out it might be ur converter lockup up at certain rpm's i could be wrong but chek wit him first. how'd u do on the dyno??? i had to down size from a 4000 2.5str to 3400 2.1str stall now i have to wait a lil
Old Sep 13, 2007 | 10:12 PM
umm 374 rwhp, thats avg for just the 98-00 intake. If it was 40 degrees its be 10 more, or if i had a fast 90/90 and the ud pulley its make 405 ish, and if it was cold prolly bout 415... not too bad, i got a few more tricks without porting or gettin new heads to make about 425Rwhp on a decent weathered day. Yhea i think its in the locking of the verter, cuz if im slowley accelerating and step on it it shifts immediatly, i think it lockes and takes a while for it to unlock. Gotta get it changed
Old Sep 13, 2007 | 10:28 PM
DSRCAM's Avatar
yea tha only differences between our cars is the heads i got ported, i hope u enjoy ur car, thats not to bad for a cammed only car, hopefully ill hit round 415-130ish i hoping for that..
Old Sep 13, 2007 | 10:48 PM
ur porting stock heads, or u got new heads? If they flow good u should make alot more then that. Without flowing them i was gunna get some 1.75 roller rockers, and change the lifters, and while the heads were off i was going to mill them and raise the compression. It would make my lift about .615 / .621 instead of the .598/.603, and would raise the compression. That along with the fast 90/90 and the UD pulley should pick up 40 to 50 horses. Thats bout 425. Porting them will only raise your h/p even more...
Old Sep 13, 2007 | 10:54 PM
DSRCAM's Avatar
yea i got them raced ported to the maxs i got pics if u want to see them, their 806 heads, like i said ill post pics if u wnna see them but yea i got a whole new pretty valvetrain from oil pump to dual springs to lifters to pushrods.. i spent a total of 2250.00 or so not including the gears yet and efi live thats im gonna learn and tune my own car
Old Sep 13, 2007 | 11:06 PM
wait im confused, maybe im over looking something... we have 241 heads stock... what are 806's.. are they actually a different head, like u swapped em on?
Old Sep 13, 2007 | 11:13 PM
DSRCAM's Avatar
ill send em to u ok ur bout to recieve an pm
