Paging all TH400 guys.....got a vibration question......
Then while cruising when I get up to like 50-55 it starts to vibrate in a steady pace, sometimes it sounds like the car wants to come apart...but its built strong, so I assume it wont...
The worst of it is when I got all out full 1/4 mile blast....and get up to like 115-120, then let my foot off, it shakes the whole car pretty bad....
Any ideas on what this is?
My car does EXACTLY the same thing. I'm thinking it's one of two thing or a combination of both. I know my driveshaft is out of balance. So I'm hoping a dennys driveshaft will cure that part of it. The other part is I think that when I drilled the holes in the flexplate for the JW converter that I didn't get the converter exactly centered on the flexplate. This would definately cause a vibration. I know that this is also the case with my car because when I put the car in neutral and rev the engine slowly to around 3000 rpm I get the vibration. So I would have both of those things checked out.
Will
I've made a converter change since the JW....I kind of miss the hit of that old converter... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Any other way to figure out exactly what it is....
I will address the issue of the flexplate with my installer and see if they centered the converter right on the flexplate....I wonder if drilling holes where they weren't originally would throw it off balance?
if not, who made it?
the flexplate (or flywheel to some of you) might be warped also, try rotating it like 90-180 degrees...
steve frank
The flexplate might be warped, thats what I think it would be...is there any way to prove that theory wrong, wouldn't mind having someone look under the car while I'm driving and looking to see what the hell is shaking so hard...
<small>[ December 10, 2002, 09:52 PM: Message edited by: BIGBOS ]</small>
why did changing converters eliminate alot of this vibration? i remember the first time i rode in it with the jw and i thought the mount was busted thats how bad it was shaking. remeber when we raced the guy on the EOX comin home from fratos? could it just be an inherent part of having a race converter?
I have a tach on my dash, and the vibration causes it go go blurry...thats how bad it shakes....thats after I let off of like a 120 mph run...
When my tranny was first installed, it never had any issues with this. When I pulled everything out to rebuild my motor last year, the vibration began after installing everything.
What was changed? Had a friend go through the tranny and rebuild it. Sent the converter back to Yank for a refresh. No change to flexplate. No change to DS. So I figured it was just a slopppy tranny rebuild.
A friend is getting the tranny/converter setup from me, but we are having the tranny redone by Carl Rossler and gonna send the converter back to Yank again for refreshing. Hopefully, his car will be vibration free.
I want to know of the change in DS helps you guys out! Good Luck!
I might have access to a lift this friday, if not I will wait till my car goes into the shop in spring and have my installer fix it..
<strong>Did you check your pinion angle compaired to your tranny output angle? Might be something you should check.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You should really check this. The pinion angle and the trans output angle need to be paralell or else there will be vibration problems. The pinion angle might be changing as it goes through the suspension travel.
<small>[ December 12, 2002, 10:42 PM: Message edited by: CONFUZED ]</small>
Todd
