need help deciding what to do...second gear slipping bad
Old Sep 19, 2007 | 07:13 PM
TreyNoahLS1Camaro's Avatar
Default need help deciding what to do...second gear slipping bad
K i have 2002 z28 Auto!!
after i bought the car 2weeks had gone by and it started to slip in second gear. It was still under warranty ( used car one i had to pay 50%) Well they said that a eletric part had gone bad and caused a drop in pressure which burn my clutches( which was second gear bands)
So now 3 months later and the damn second gear is slipping again. I need some advice on the matter. I dont wanna put it back stock...im scared the **** is gonna break again. CAr has only 72000 miles.
Old Sep 19, 2007 | 07:18 PM
performabuilt's Avatar
LS1Tech Sponsor
Well you could purchase a built unit , However that would not be covered under the dealers warranty .That would be my advice wether its from us or someone else
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 19, 2007 | 07:26 PM
i have no warranty on the car anymore... that why the transmission i buy has to last me.
Old Sep 19, 2007 | 07:27 PM
LS1Tech Sponsor
Well then I would get a built unit with a good warranty!
__________________
Call 888-744-6542
Old Sep 19, 2007 | 07:31 PM
from where? should i stick with a 4l60e or swap to something else?
Old Sep 19, 2007 | 08:21 PM
big wally 55's Avatar
Default second gear problem
The slip in second gear is not usually caused by an electrical problem , and the dealer would probably not have payed for a "Quality" rebuild . Most just want the cheapest fix just to get you out of their hair . If you get a good rebuild done on your 4L60E it should give you a long service life !!
You say you don't want to go back stock . Our shop ,as well as some of the other sponsors on LS1 can build you any thing that you need . Just give us a call and we can point you in the right direction !!!!
Old Sep 19, 2007 | 08:55 PM
LS1Tech Sponsor
As our signature says thats what we do lol. And unless you have alot of money or plan on a massive build up I would stay with a 4L60E
__________________
Call 888-744-6542
Old Sep 19, 2007 | 09:22 PM
gruntwork's Avatar
I'd stick with the 4L60E. Great streetablility w/overdrive, and no custome fab to make it mount right. Definitely get a built unit, cuz believe me I know, you'll just keep breaking the stock one, esp. with heads/cam or poweradder. A well built 4L60E from a good place can handle quite a bit now a days.
