4L60E techs
Old Sep 26, 2007 | 10:28 AM
golfcartracerx's Avatar
Thumbs up 4L60E techs
I have a 96 LT1 Firebird that threw a code other day. Cde was P1870. Trans has 144k on it. What should or can I do about this? Thanks for any help
Old Sep 26, 2007 | 10:48 AM
performabuilt's Avatar
LS1Tech Sponsor
Code P1870 is the code set for excesive converter slip . Generally its caused by one of the following. 1- restricted PWM solenoid screen, 2-worn converter lockup clutch, 3- worn Converter regulator valve bore in valve body , And with that number of miles its likley all of the above I am afraid .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 26, 2007 | 10:53 AM
So my best bet would be to replace the converter and if so do i get a oem replacement or ?
Old Sep 26, 2007 | 11:18 AM
LS1Tech Sponsor
Well actually short of rebuilding the trans or replacing it (best ideas)
You would need to replce the converter, PWM solenoid and possibly the valve body .
__________________
Call 888-744-6542
Old Sep 26, 2007 | 01:50 PM
Would a 4L80e be a perfect swap or is there modifications needed?
Old Sep 29, 2007 | 07:32 PM
Do I get oem converter-PWM solenoid and valve body or should I go with a certain brand?
Old Sep 29, 2007 | 07:58 PM
87gnx's Avatar
This seems like the perfect thread to praise the gang at Performabuilt!!. I bought a converter from them(for wifes' B4C Camaro) and have had nothing but good solid runs with it!! I build it she drives it(well if i'm good I get to go gas it up sometimes).They are straight shooters who do an outstanding job, when the trans dies, I'm getting one from them!!. $.025
Old Sep 29, 2007 | 08:05 PM
LS1Tech Sponsor
Thanks 87gnx , And for golf cart no a 4l80e would not be a direct swap and yes if your dealing with the sock trans and want to try that before upgrading get a reman converter and then those solenoids from GM
__________________
Call 888-744-6542
