4l60 question
Old Oct 1, 2007 | 08:52 PM
Poor Kid's Avatar
Default 4l60 question
Just had a new 4l60 built for a 99 camaro. Put in a known good yank 4000 stall, and the car didn't move. Put the scanner on it, and it had no input shaft rpm. Took the trans back out to find the splines on the new input shaft worn down almost all the way. Is there any reasonable explanation for this? thanks
Old Oct 1, 2007 | 09:10 PM
performabuilt's Avatar
LS1Tech Sponsor
What was the converter in last ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 2, 2007 | 12:45 PM
Poor Kid's Avatar
The conv. was in a T/A before. We took it out of the T/A, Drove home with it and put in the camaro.
Old Oct 2, 2007 | 01:07 PM
LS1Tech Sponsor
I would have to beleave there is some issue with that converter, You said it was in a T/A but what year is each car?
__________________
Call 888-744-6542
Old Oct 2, 2007 | 06:26 PM
Poor Kid's Avatar
the camaro is a 99 and the T/A is an 02
Old Oct 2, 2007 | 07:43 PM
LS1Tech Sponsor
Well there wasnt a mismatch there but the converter is still suspect, Is there any way you could take picks of this splines that are messed up on the trans now?
__________________
Call 888-744-6542
Old Oct 2, 2007 | 08:36 PM
Poor Kid's Avatar
i'll try to wed. thanks
Old Oct 2, 2007 | 09:12 PM
LS1Tech Sponsor
Oh and was looking at your OP and you say you put a scanner on and there were no input shaft rpm. And there wouldnt be since the 4l60e has no input speed sensor. It only sees engine RPM and OUTPUT speed just FYI .
__________________
Call 888-744-6542
