View Poll Results: computer or manualy shift?
computer
58
85.29%
manual
10
14.71%
Voters: 68. You may not vote on this poll
computer shift OR manual shift??
Old Oct 6, 2007 | 08:20 PM
motownZ's Avatar
Default computer shift OR manual shift??
just want to know
Old Oct 6, 2007 | 08:25 PM
Gilbert@Ace Racing's Avatar
That is a bit of a loaded question. Meaning... is this a track application? What gears are your running?
The 4L60E has a low 1st gear compared to a bunch of automatics. When that unit is coupled with a non stock rear gear it can be a bit of a learning curve trying to get it into 2nd before hitting the rev limiter.
g
Old Oct 6, 2007 | 08:28 PM
blueeyeddevil141's Avatar
g
I have a 3800 stall, 3.73's, and have never hit the limiter going into 2nd lol.
Old Oct 6, 2007 | 08:31 PM
Hey that's a good thing! Not everbody has a hard time, it is very driver/vehicle specific.
g
Old Oct 6, 2007 | 08:39 PM
motownZ's Avatar
im talking about stock, sorry i didnt say that
Old Oct 6, 2007 | 08:49 PM
Not sure what you are asking Motown... are you asking opinions about going to a manually shifted stock 4L60E? If so, I do not recommend doing it. To do so would put undue stress on an already tired unit... if of course it is not being rebuilt at the time it is being converted to manual.
g
Old Oct 6, 2007 | 08:51 PM
motownZ's Avatar
g
sorry im really trying figure out what every ones opinions on either and what users do. and basically for the track.
pros---- cons
Old Oct 7, 2007 | 01:36 AM
performabuilt's Avatar
LS1Tech Sponsor
For the track with and auto version a properly uned PCM will do you best, If you want to go manual you should convert to full manual .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 7, 2007 | 01:15 PM
FLT's Avatar
FLT
I voted to let the computer do it's job. Vince
Old Oct 7, 2007 | 01:21 PM
Greaseymec's Avatar
I like the consistancy that the computer gives me on the shift. Its usually no more than 100 rpm off from its usual shift points (using datamaster and comparing runs). My 2-3 line pressure also does better on the computer (with OD selected). The car has run VERY consistant this way. .005 of a second difference between runs in not uncommon for my car. So if you want consistant times at the track, let the computer do the work!
Mec
Old Oct 7, 2007 | 02:58 PM
bmxer8699's Avatar
if your at the track let the comp do its job, if your on a roll and dont really care for your tranny, then drop it into a lower gear to keep the rpms up.. i wouldnt recommend that though
Old Oct 7, 2007 | 05:54 PM
CamaroRacing12's Avatar
dont get cocky, put her in D and get on it!
Old Oct 7, 2007 | 07:17 PM
98REDZ's Avatar
get a 3500+ torque converter,....thats my input
Old Oct 8, 2007 | 12:18 PM
Strahley's Avatar
If it's an electronic trans, let the computer shift it. You aren't going to gain anything trying to shift it yourself
Old Oct 8, 2007 | 10:12 PM
PBA's Avatar
PBA
If the shift points are where you want them....... then leave it in "OD", not "D". There would be "no benefit" from you shifting it.
Old Oct 10, 2007 | 12:36 PM
silver-mod-o's Avatar
Custm2500's #1 Fan
drop it in go, and let her be...
Old Oct 10, 2007 | 08:42 PM
motownZ's Avatar
you said OD:: which i got better times on at track. but some say D instead of OD bc it wont hit od on track.
what does everyonw say about that
but thanks im 100% sure i wont manulal shift my car
Old Oct 10, 2007 | 10:23 PM
Camaro396's Avatar
i manually shift the **** out of my 4l60e and it probably hates life. im sure it will blow up one of these days.
Old Nov 1, 2007 | 08:46 PM
FiredUpZ28's Avatar
I dunno bout you guys but I don't even hit the top of 3rd at the track with a 3.42 A4, so in D or OD it will never hit 4th gear. At least not stock.
Old Nov 3, 2007 | 12:38 AM
99 Pewter TA's Avatar
4l60-e means computer shifted. Let it do the work. I had a buddy shift to 2nd on a highway and pushed it. The end result was a hole in the block
