Install writeup on Moser 12 bolt??
Old Jun 12, 2003 | 12:08 AM
ExtremeZ28's Avatar
Default Install writeup on Moser 12 bolt??
Just wondering if anybody has a good writeup on what im going to need/do for this install?
Thanks for any help its much appreciated
Jay
Old Jun 12, 2003 | 01:17 PM
ExtremeZ28's Avatar
Default Re: Install writeup on Moser 12 bolt??
ttt,please any help would be much appreciated
Old Jun 12, 2003 | 05:41 PM
Mustang Hat'r 2's Avatar
8 nuts for the backing plate bolts
need to get the barings pressed on the axles
need some break clean to clean out the inside of the housing
rearend fluid type/kind???
4 bolts for the torque arm the ones they send are to short pitch/size???
RTV/gasket maker I alwas use this instead of the gasket
Thinks thats everything hopefuly some one will fill in the little details
Old Jun 12, 2003 | 06:54 PM
bomax's Avatar
If you have aftermarket LCAs you will want LCA relocation brackets, the only ones that will fit the Moser are that the Spohn ones from www.spohn.net. They are weld on style. You will also need the weld on sway bar kits
Old Jun 13, 2003 | 06:48 AM
I forgot about that and you need 2 3inch exaust clamps, might need new sway bar bolts I have broken them every time I take them off. Also a small peice of metal tubing for the sway bar it goes inbetween the bushings.
Old Jun 13, 2003 | 10:27 AM
Mike K.'s Avatar
Here is a write up, not the best one but hopefully it helps
http://www.fbody.com/tech/details.cgi?id=3
Old Jun 13, 2003 | 11:34 AM
nc z28's Avatar
i had to use a different u joint on mine.
Old Jun 13, 2003 | 12:09 PM
ExtremeZ28's Avatar
cool thanks guys im just trying to get somewhat ahead of the game so i know what i need, any other helpful hints/tips or anything of that nature is much appreciated
