Which clutch wires do i jump?? HELP!!!!
Hey guys,
I had my M6 - A3 swap done last week. The guy couldn't figure out what wires to splice together to make the car start.
I do not have my M6 pedals in the car anymore so all the clutch sensors went with the pedals, but I have a harness not plugged in and it has 4 wires on it I think![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
Someone mentioned the black and white, but theres only 1 black wire and it has white stripe and there is no white wire.
Can someone please explain what 2 exact wires I need to splice together. Maybe even show a pic.
This is the last thing I need to figure out so I can be done with this swap
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
The two that went to this switch http://img.villagephotos.com/p/2005-...pWiring004.jpg that switch is on an A4 to M6 swap, your colors are green and purple and you should have a plug on the end of them. Tie the green and purple wires together. There are stripes on the wires but I forgot the colors.
try that. I have not gone from an m6 to auto so im just going off what I read.
look under the dash for the wires to splice together for the clutch switch
be sure to read this thread
https://ls1tech.com/forums/automatic-transmission/200477-m6-a4-a4-m6-conversion-info.html
If you ever plan to take it to the track you should wire these to a neutral safety switch.
Just so this is clear
It's a blue clip with a purple and green wire and you splice them together and what do you know the car starts!!!!
Thanks for the input. It was actually simple to figure out once I actually got under the dash. It's the only clip with 2 wires on it
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
