colonel converter
Old Jan 21, 2003 | 09:28 PM
finalymodded's Avatar
Default colonel converter
Have you lost any topend with your converter?
Old Jan 22, 2003 | 11:49 AM
Colonel's Avatar
Default Re: colonel converter
Impossible to say. The converter wasn't the only mod made between track trips but it's been my experience that a good converter actually helps trap speeds.
I went from running 12.68@107.64 to running 11.82@113.12 from one track trip to the next but there were several changes so it's impossible to say what did what. A 6 MPH increase with NO internal modifications or serious weight reduction is alot. It was a combination of...
Going from a 2400 stall to a 3500 stall.
Underdrive pully.
Headers/no cats.
Exhaust cuttout.
Better weather.
LS1Edit. Changes shift points, raised timing, deleted TQ management.
Take your pick as to what did what. My guess is this converter is good for about 2 MPH over the stock converter.
Old Jan 22, 2003 | 01:18 PM
pedaltothemetal's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by leanne:
<strong> thanks colonel but i see you have pullies on an auto do you recomend that? Alota people say it will cause problems, because of the electronic tranny,(and i have a larger stereo system. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">With my convertor I increased idle speed to 1000rpms so even with my underdrive pulley my electrical system is not taxed at idle.
Leo
Old Jan 22, 2003 | 01:52 PM
thanx for the reply, i didn't think of that. The converter would almost off set it. Thank you!
Old Jan 22, 2003 | 02:26 PM
Colonel's Avatar
Leanna, Leo didn't mean that changing the converter raised the idle speed. It won't. You have to do that through programming.
For an A4 I recommend doing the underdrive crankshaft pulley but not the alternator pully. I never had any problems with my fairly big sound system in my '00 when I used to run it with an underdrive pulley. If you found that the charging wasn't enough for you then you could either raise the idle speed or install an alternator overdrive pulley.
Old Jan 22, 2003 | 02:53 PM
Yeah i knew he raised idle i just hadn't actually thought of that, so... if i add a cam and bump my idle up to 1000 it'll offset it anyway eh?
Old Jan 22, 2003 | 04:49 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Colonel:
<strong> Going from a 2400 stall to a 3500 stall.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">...should account for a little. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 22, 2003 | 05:38 PM
<strong> thanx for the reply, i didn't think of that. The converter would almost off set it. Thank you! </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You're right! Forward creep is just like stock, and will hold on a grade with your foot off the brakes.
Leo
Old Jan 22, 2003 | 06:32 PM
Colonel's Avatar
<strong> Yeah i knew he raised idle i just hadn't actually thought of that, so... if i add a cam and bump my idle up to 1000 it'll offset it anyway eh? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ok, just making sure you were clear on that. I have seen people get confused about that one before.
Stock, an A4 idles at about 550 (it may vary according to year) in gear. Underdrive it %25 and it's like idleing at only 412.5 RPM. So, raising the idle to 687.5 would get it back to stock as far as the alternator is concerned. 1000 would be way more than enough. The idle out of gear is 650 so adding %25 gives us 812.5.
Old Jan 22, 2003 | 11:57 PM
wicked 98z's Avatar
I have a pully with my a4 and a large system. Car idles at 1k with no charging problems with the cam.
Old Jan 23, 2003 | 12:28 AM
Old Jan 23, 2003 | 09:15 AM
PlanoZ's Avatar
Colonel- what kind of shift extension does this verter give you?? 1-2, and 2-3?? TIA.
Old Jan 23, 2003 | 10:58 AM
Colonel's Avatar
I just looked at the 4 runs I Autotapped last time at the track and the WORST shift extentions between all four runs were...
4738-1/2 shift
4879-2/3 shift
This was with the shift points set at 6300 on the 1-2 and 6200 on the 2-3.
Old Jan 23, 2003 | 06:00 PM
WJ SOM SS's Avatar
Colonel: Did you ever install those lca re-location brackets and did they help you at all? ('02 car) Thanks & best wishes. WJ. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 24, 2003 | 11:30 AM
Colonel's Avatar
Yes I did. It's always hard to say for sure if something helps traction much since track prep varies so much but I did pull some 1.61 60 ft times on drag radials last time out. This was FULL weight and with the front swaybar intact.
