Broke the trans pump??? Here is how to fix it..
I put in a YPT4400... and fired up the car today... no gears.. everything acts like neutral.. linkeage is hooked up.
The converter was very hard to turn on the input shaft. I seeked advice and the consensus was to just put it on, it should be ok... well.. now I have no gears.
The solution
The converter should spin freely when put onto the transmission. If it takes any effort at all something isn't right. Through the knowledge I obtained from this thread I was able to put together a trans pump info page for those of you who wish to attempt this yourself. It's not really that hard, just takes some time. You save labor $$ by doing the work yourself. My mistake only costed me $125 when it has costed others near $1000.
The link to the page is in my signature. Or you can click here:
http://www.dxsoftware.com/magnus/
In the left contents menu just click Trans Pump.
I hope this helps.
Once again thanks to all that chimed in this thread with useful and supportive information.
Below is the learning process I went though. It's good reading material that I will leave in this thread.
I do have a tranny cooler.. but I don't need to pull a line off to know I don't have line pressure. What did you do to fix it? Can it be fixed from the underneath? I'll probably pull the trans anyway.
Thanks for the reply man... I really appreciate it.
If your converter is turning engine speed then so is your pump suposed to be. If you've got enough oil in the pan to cover a properly installed pickup filter, and with your cooler lines off, trany fluid should be spraying all over the place. If no fluid spraying and your fluid level not going down(I'm assuming your checking the fluid level and relize you gotto fill this new converter"no sarcasizm intended") ... Then pull the trany and pull the pump. Putting a pump in one of these things is not that difficult.
Don't run it too long as not to tear up your new converter any more.
My trany is scattered in my garage right now waiting on parts. I can maybe help you some with this.
Sorry about your luck ... Ron
Now all I need is a little how-to on tranny pump swap? Car is raised and I'll be dropping the trans pan in a few, just to look.. however I'm assuming Ih ave to drop the entire tranny and remove the pump out through the front.
The car only ran for about 5 minutes.. so I hope everything is ok.
Can't get that front cover off to reveal the trans pump.. I'll pick it back up tommorow.. any more suggestions?
** special tools/suplies: 1/2" drive torx bit. Trans lube to hold check ***** in place dureing reassembly. a couple big cans of non petrolium base cleaner(I use brake clean).
* pull the bell housing off(makes job a whole lot easier) torx head socket needed 1/2" drive prefered. bolts a very tight. I used a cross bar to keep trans from spining while breaking the torx head bolts loose.
* pull valve body down(you need it off to acces holes to pop the pump up). CAREFULL of check *****. try to keep them in place(for referance)on the valve body plate.
* unbolt the pump and carefully pop it up out of it self alighing seal seat.
... I have a Helms manual and a digital camera and can send you some pics of what, where, and how if you'de like. I have to work at home all day. I'll check back with you later.
... Ron
I was under the impression that I had to pull the front cover off of the trans... the one that the shaft goes through.
I will go right now and take a few pics and send them to you e-mail. I'll first send you an e-mail with no attatchment so you know it's me.
Ron
I'm pretty sure that should be good for now. I assume I seperate the pump halfs and install my new pump half and then just reassemble.
Can I do this all with the tranny upside down or should I have it right side up. It's currently out of the car. I just don't want check ***** to roll all over.
You might want to pull it apart first to see what all you need before ordering parts, just so you don't find out you need something else.
... Ron
I just e-mailed FLP and asked how much to swap the pump for me.. we'll see what they say.
