TH400 as a DD
Old Jan 15, 2008 | 11:17 AM
import slayer's Avatar
Default TH400 as a DD
I was just wondering if anyone here daily drives a TH400? If so how do you like it? What are the advantages and disadvantages? What stall do you have with it?
Old Jan 15, 2008 | 11:35 AM
troopercar's Avatar
TH400's were daily drivers long before there were overdrives. You get used to it unless it's an all interstate car. I'm assuming it's mostly drag racing you do with it.
Pro: strong as a backhoe
con: no overdrive gear
Old Jan 15, 2008 | 12:09 PM
No, I would be driving it everywhere.
Old Jan 15, 2008 | 12:18 PM
troopercar's Avatar
I meant the reason you were looking to go turbo 400. I assumed it was for it's strength. It's no harder to live with than any other auto, just uneccessary unless the car's a beast.
Old Jan 15, 2008 | 01:13 PM
Are they bad on the interstate? Why? Sorry if these seem like dumb questions but I have never driven in one.
Old Jan 15, 2008 | 01:16 PM
Razor_Blade's Avatar
Just drive around in D instead of OD for a couple of days.
Old Jan 15, 2008 | 03:17 PM
DanZ28's Avatar
My car with 4.10's and 26" tires is about 3000 RPM at 55 mph. Thats why it's not a good DD tranny, plus the drop in milage. Like posted above, just put your 4L60E in drive and go everywhere like that and see how you like it.
Old Jan 15, 2008 | 04:03 PM
SS101's Avatar
a 4l80e would be more expensive but a good compromise...they're much stronger than a 60e and will spin much lower on the interstate because they are overdrive.
Old Jan 15, 2008 | 04:05 PM
troopercar's Avatar
Not if you have a 2:73 gear. Bad on the interstate is relative. When I was a kid you were in a fancy car if you had OD
Everything GM made was TH350 and TH400's. My old Z28 was a 4spd manual with no OD, never bothered me a bit. However, once you get used to cruising the interstate with OD at 90mph you get spoiled.
TH400 is like a Dana 60, if you need it because of your insane power get it. If not, why bother?
Old Jan 20, 2008 | 06:12 AM
revtime's Avatar
They are very livable with a 2.73 or 3.23 gear, go lower (3.73 or 4.10) and you won't like it very much.
I run a TH400 in my 94Z. Its a bolt on car nothing too radical but I got tired of breaking drivetrain parts and just went over kill.
It only gets driven on the weekends during the summer so its easy to live with my RMVB TH400 and 4.10s with a spool.
Old Jan 20, 2008 | 07:07 AM
robertbartsch's Avatar
I used to rebuild these in the 1970s.
They are rock solid - strong as hell! Unfortuntately, no overdrive and one other thing no one else mentioned: they weigh a TON!
I would not recommend this unit for a DD, expecially with gas prices approaching 4 bucks a gallon.
I thought this unit was not used frequently for drag racing either since it weighs too much.
Old Jan 20, 2008 | 10:59 AM
CamaroKidZ28's Avatar
I currently have a TH400 with 2300 stall.. on the highway, i cruise ~60 being im at like 2750 RPMS. Its strong though, im making 500 / 550 and its holding up
Old Jan 20, 2008 | 11:15 AM
Top Fuel's Avatar
Mine is not a daily driver and I absolutely hate it on the highway. The city is fun as **** though. Once you get past the fact that your car is going to guzzle gas, its more perception than anything else. If you have a relatively quiet exhaust, dont pay attention to the tach, get into comfortable groove, or better yet set the cruise the highway isnt going bother that much. My problem is that I have a loud exhaust, no cruise, and I worry about my coolant temp running hot so I'm constantly checking that on the highway.
Old Jan 20, 2008 | 11:27 AM
Josh@KY-Turbo's Avatar
I drove my full tilt RMVB T-braked TH400 in my last 370ci 76mm Turbo Car on the interstate, in town, hell everywhere. It had a 9" with a spool, 3.25 gears, MT 325/50/15 DR's. I could cruise on the interstate 70mph around 3100rpm. The drivetrian didnt mind. The cooling system didnt like it very much. I needed bigger fans. I am going to a TH350 this time around with the new turbo car.
I will say that Vettes and the occasional Viper I meet on the interstate that wanted to play were pissed when I nailed.
Old Jan 20, 2008 | 02:43 PM
jxaxsxoxn's Avatar
Ah the memories,
I used to drive my 1966 427/RMVB th400 powered 1975 nova to the track, 30 minutes highway drive with open headers at 5000 rpm.
What really sucked was the time it broke the shift cable and I drove it 5000 or so rpm at like 30 mph stuck in 2nd, that was over an hour drive home. Could've used some ear plugs that night.
Old Jan 20, 2008 | 03:01 PM
Top Fuel's Avatar
Thumbs up
Originally Posted by jxaxsxoxn
Ah the memories,
You my friend, are a man's man.
Old Jan 24, 2008 | 04:14 PM
Yeh, when I was building trannies in the mid 70s, a guy came in to the shop with a TH400 race car.
This car - 69 Firebird - had a +500 cube motor with 2 holley 4 barrels mounted on a very high sheet metal intake - no hood. Car was tubbed - Slicks were huge! The cam was so big, the car did not idle.
Anyway, I had to test drive the TH400 on the street after the build. ...That ride I will not forget!
Old Feb 19, 2008 | 10:00 AM
B18CYA's Avatar
anyone else out there with th400/350 gear ratio tire height rpm speed?
Old Feb 19, 2008 | 06:06 PM
troopercar's Avatar
350/400 top (3rd) gear is 1:1 just like a 4l60E in 3rd or an M6 in 4th
Old Feb 19, 2008 | 08:23 PM
wichoms4's Avatar
Mine Is A Dd. Hate The High Rpm In The Highway. Im At 3000rpm Going 60mph. Have A Vig 3600 Stall, Stock 3.42's On 17in Rim. Love Driving In The City. But The 4l80e Is The Best Way To Go If Its A Dd. Strong Tranny And Has O.d.
