what converter and gears do i need?
Old Jul 6, 2003 | 12:07 PM
Need2gofaster's Avatar
Default what converter and gears do i need?
My best 1/8th time is 9.019 at 81.114 mph 60' was 2.101 best with the mods listed below. I know the car is capable of much better times with a converter and gears. It's not a everyday driver for me so i'm not worried about that. I was thinking a 3600 with 4.10 gears. Any suggestions on brand or if that combo is right?
Old Jul 6, 2003 | 04:56 PM
42NightZ28's Avatar
Default Re: what converter and gears do i need?
if its not a Daily driver then and all your looking for is 1/8 mile times then the skys the limit, 4200-4400 YTP will net great times. As for the 4.10s you might think of beefing up the rear or buying a 12-bolt or 9in first.
Old Jul 6, 2003 | 05:24 PM
What i really want is good 1/4 mile times. i just ran the 1/8 mile to see what i'm doing at the 60'. The nearest 1/4 mile track is alot farther away and the 1/8 mile is 10 min away. What do you think would be the best for the 1/4 mile? 3200-3600?
Old Jul 7, 2003 | 08:48 AM
Ragtop 99's Avatar
How hard core do you want to get?
A Yank YTP 4400 or TCS 4200 stall and nittos will have you pulling 1.6s with your stock gears. 3.73s would help a bit (assuming you have traction) and 4.10s would be better if you plan to run a larger diameter tire like 26.x11.5x16 ET Streets.
Old Jul 7, 2003 | 02:16 PM
Will a 4200 to 4400 be to much in the 1/4? I was thinking about a 3600-3800
Old Jul 7, 2003 | 03:00 PM
Ragtop 99's Avatar
Most of the fastest LS1 cars run 4000 - 4400 true stall.
Old Jul 7, 2003 | 08:43 PM
DEEZ98Z's Avatar
I wouldnt go any any lower than 3.73's on an auto car. Every TC is different.... like my VIG 3600 actually stalls around 4000... that with some 3.42 or 3.73's and traction you will be hitting some low 12's
Old Jul 8, 2003 | 10:37 AM
I have 4.10s on order....someone please tell me if i should go with the3.73 or 4.10...what i want is a good 1/4 time. i also have the 3600-3800 vig on order with a power programmer and 125 shot of nos. HELP HELP!!!
Old Jul 8, 2003 | 12:56 PM
Ragtop 99's Avatar
Do not get 4.10s if you are going to spray a stock cam & valvetrain motor without tall tires. You will run out of rpm in 3rd gear.
Leave your gears alone. install the vig & NOS and see how you do first.
(7/6/03) I was thinking a 3600 with 4.10 gears. Any suggestions on brand or if that combo is right?...
(7/8/03) I have 4.10s on order....i also have the 3600-3800 vig on order with a power programmer and 125 shot of nos.
Next time, post all the the info up front.
You had already made up your mind and ordered stuff, so let people know that.
Second, Nitrous makes a HUGE difference in what is optimal. Do not hold back key facts about mods that can make a difference in determining what is right.
Sorry to go off topic here, but this happens occasionally and is not fair to the members that take time to answer questions that are really moot or lead to bad advice. Hopefully others will read this and incorporate into their future postings.
Old Jul 8, 2003 | 06:06 PM
I did not order the parts untill yesterday afternooon, and had othe postings with people telling me to get 4.10s and a 4000-4400 tc. And i did not know about what the nos did so there is no way i could have done anything different. But now i know and wont do it again.
Old Jul 8, 2003 | 07:49 PM
Jorday's Avatar
I agree with Ragtop, try the converter first and leave the gears alone for now.
Old Jul 9, 2003 | 02:48 AM
42NightZ28's Avatar
if you must get a gear get a 3.73 as rag top said you WILL run out of gear in the 1/4 with a 4.10.
