....Daily Driven TH400 users withing.......
Old Jul 6, 2003 | 07:01 PM
99taws6's Avatar
Default ....Daily Driven TH400 users withing.......
I want a tranny that will hold up to many mid 10sec passes without crapping out on me. I think that it is a crap shoot with the 4l60e's.... I need to know about the TH400's.
I drive approx 100 miles a day. Most of it is between 55-75mph on the highway. I would be using 3.73 gears and stock tire height. Will the TH400 be ok for this or am I biting off more than I can chew?
The tranny I am looking at is a Yank w/4000 stall and trans brake. It has a reverse manual valve body.
I could cut my driving down to 50miles per day if I had to, but would prefer not to.
Let me know your experiences/suggestions.
Old Jul 6, 2003 | 09:04 PM
mjf454's Avatar
Default Re: ....Daily Driven TH400 users withing.......
It would be the same as driving your 4l60 in 3rd gear on the freeway. I drove a t400 with 4.56 and 4.88 gears for years, i like it.
Old Jul 6, 2003 | 09:33 PM
99taws6's Avatar
I kinda figured that a 1:1 ratio would be the same.. I am wondering how it is without the locking convertor, how it is on heating up. I want to hear from people who daily drive them.
Old Jul 6, 2003 | 10:35 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
I drive my th400 daily. The same one your going to get cept for a 3600 stall and 3.42 gears. With my gears at 65 im little over 3000rpms. Also I dont mind the tranny cause I know it will hold up unlike some 4l60s I had. I would drive around with yours in 3 rd all the time and see how ya like it. As far as the always unlocked its not to bad it was hard to get use to but after awhile I got use to it.
Old Jul 6, 2003 | 10:40 PM
99taws6's Avatar
How far is it driven daily? What power level are you at?
Old Jul 7, 2003 | 10:08 AM
FEAR THE LS1's Avatar
I have a TH400 with a Yank SS4000E converter and 3.73 gears with stock tire height.
I drive my car daily to work, luckily I only live 8 miles from work. But, there is no way I would want to drive 75-100 miles a day, especially on the highway with the 3 speed.
I have to drive 65 miles to the track to race and it kinda sucks, I would hate to do it daily. The car just sucks down the gas from driving at 3000-3500 rpm on the highway for 75-100 miles.
If you work that far from home and have to drive the car daily and you want a TH400, then get an over drive unit for it, like www.gearvendors.com etc.
Old Jul 8, 2003 | 01:18 PM
Cool28's Avatar
I drive about 20 miles a day. With about 450rwhp. Its not bad since its all back roads but on the highway I just dont like it reving past 3500rpms. I dot about 65mph on the highway which is about 3100-3200rpms. The thorttle response is great though . Maybe it would be ok if ya had a quiet exhaust. I have dual cutouts so its kind of lound :p
Old Jul 8, 2003 | 01:33 PM
CHRISPY's Avatar
Why not buy a 27 inch street tire or something similar?
Also you can go down to 3.42 without too much loss in performance. (Get a 2.75 first gear to make up for the gearing drop)
Cheers,
Chris
ps- If I went with a TH400 I would get the 2.75 first gear, 3.42 rear gears and drive on a 27-28 inch DR on 15's. With a transbrake and a 3500-4000stall converter you'll still fly on the track
Old Jul 8, 2003 | 02:12 PM
Linear Velocity's Avatar
One answer, 200-4R. If built right they can take lots of HP(buick guys are runnings 9's with them), have less drivetrain loss than a Th400, and a .67 overdrive. They have a 2.62 first, you can use a transbrake on them, and they have a lockup convertor. Perfect if you want a tranny that will hold up to 10 second passes at the track and still cruise on the highway.
Old Jul 9, 2003 | 09:15 PM
2001-WS6's Avatar
You are right it's a gamble on the 4l60e.
I've got an FLP level4 with 10K miles behind the MTI 422 and averaging 40 miles a day. It's about 460rwhp on motor. We're looking at about 620rwhp on 150 shot. I'll let you know how the mid 10s hold in a few weeks.
By the way my 3000 RPMs is hanging closer to 80mph on the freeway with 3.73s
Rick
Old Jul 9, 2003 | 09:31 PM
99taws6's Avatar
A few weeks may be to late, but let me know..
What are your best slips to date?
Old Jul 10, 2003 | 06:12 AM
JimmyKash's Avatar
the guys who do run 9s refresh them quite often....also the cost of one that will withstand that type of abuse will set you back close to $3000 all said and done including converter
you could build a TH400 with an o/d and/or a 4l80E for just as much and never worry
Old Jul 10, 2003 | 12:02 PM
TH400 with a GVOD is expensive, heavy, and has lots of drivetrain loss. The GVOD alone adds 100lbs and is $2500, that's much more than a 200-4r that would be built for a 10 second car. Go ahead and be the first person ever to fit a 4l80E into an f-body, no one makes a kit for it, it'd be all custom work for lots of $$$, and again it's heavy with lots of drive train loss and you can't use a t-brake with it. :p
Old Jul 10, 2003 | 12:17 PM
Terry Burger's Avatar
Morgan Motorsports has done a few 4L80E / FBody installs... They are very strong but the trade off is weight, they are almost 90# heavier than the 4L60E, and less efficent.
I'm running a TH350 with 3.23 gears and its OK as a daily driver, not much worse then my 4L60E with 4.10s. I got a lockup trans and 2.75 1st gear.
Old Jul 10, 2003 | 08:56 PM
theblur98ss's Avatar
I was contemplating this same question for when my T56 dies. I came up with getting a Jerico tranny. It's expensive but in the same ball park as a t400 with overdrive and I think it's a better setup.
Old Jul 10, 2003 | 09:05 PM
2001-WS6's Avatar
Well, I've only run a 11.5 secs, at 199.5 mph on a 1.75 60' run with my Nittos this year. I blew a head gasket about 2/3 of the way down the track I'd guess. So I didn't get to make a gas rund that day.
We spec'd some new custom race gaskets and put the ARP head studs on to get some better clamping since I've smoked 3 set of gaskets in 14 months.
I'm going to try to get out to one of the local tracks this weekend to do T&T before the CamaroZ28.com Nationals get here on the 26th and 27th. Should be a fun event up at Mid-Michigan but I'd like to do more running than watching if I can.
Rick
