Some TH400 questions...
Old Feb 6, 2003 | 09:05 PM
Z-Rated's Avatar
Default Some TH400 questions...
I can across a TH400 out of an old chevy truck, are all of them the same? will they work w/ my car? what are the benefits of using this tranny? i searched but really couldnt find a whole lot
Drew
*edit* can the yank SS series converters work in these trannys? and how much is a good price for the tranny?
<small>[ February 06, 2003, 11:12 PM: Message edited by: Drew2G2 ]</small>
Old Feb 6, 2003 | 09:29 PM
highgmc's Avatar
Default Re: Some TH400 questions...
it should bolt right up (all but the top bolt)
madman sells a th400 dipstick
bmr sells a trans xmember
yank can make you the converter (mine will be hree anyday tp4200!)
Old Feb 6, 2003 | 11:09 PM
BIGBOS's Avatar
Yank sells TH400 converters, and I think most TH400's just bolt up, I have a race built one, that will basically withstand anything...
Pretty fun driving around the street leaving with the T-brake.. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I have a lokar dipstick....its like a noodle...
Old Feb 6, 2003 | 11:21 PM
Beeler422's Avatar
Back in the staging lane
Don't pass up Derek at T.C.S. for a converter either. His prices are better than anyone else, his customer service is better, his warranty is better, and Mikey's car is running 9.70's all motor with his converter. He's a sponsor too.
Old Feb 7, 2003 | 10:44 AM
Z-Rated's Avatar
So all of the TH400 have manuel valve bodies? what are the drawbacks to running this tranny in a daily driven car? and how much should a used tranny go for?
Drew
Old Feb 7, 2003 | 01:58 PM
Beeler422's Avatar
No, you can get an automatic valve body. They're just not very popular. I don't think they are as strong. I have a th400 in my daily driven car with 4.11 gears. I can't drive it over about 55 before I start burning oil. I had 3.42's in before and it was fine up to 70. I even drove it from Maryland to Texas. Again, call Derek at TCS about a converter. He can set you up with whatever stall and STR you like and you won't be disappointed. 800-284-8606
Old Feb 7, 2003 | 02:19 PM
Quick V6's Avatar
If this TH400 is from a truck with a two piece driveshaft, it may not have a slip yoke on it. It would be an additional expense, but I think a fixed yoke can be converted to a slip yoke. Also, I think there are two tailshaft lengths. You might want to check into this before you buy it.
-Greg
Old Feb 7, 2003 | 03:00 PM
Z-Rated's Avatar
I just got off the phone w/ Derek, really cool guy. he gave me a lot of info. i think i am going to keep my tranny i have now and just put a converter in it. thanks Beeler!
Drew
