TCI users in here
Old Jul 11, 2003 | 02:25 PM
scalemaster's Avatar
Default TCI users in here
just got mine install but Im not use to it yet
so my shifting from 1 to 2 dosen;t hit like it use to it's a 3500 so is that normal
Old Jul 11, 2003 | 05:21 PM
Ragtop 99's Avatar
Default Re: TCI users in here
high stalls make your shifts feel mushier. I think it is just a byproduct of the higher rpm differential from a high stall.
Just go out and mash it a few times and you'll go from to
Old Jul 11, 2003 | 08:07 PM
Kevin Winstead's Avatar
scalemaster,
Like Ragtop indicated, the shifts will lose some firmness when you install a high stall converter. That's why people usually install a shift kit at the same time. TCI's shift kit for the LT1 and LS1 4L60E is part number 376001.
Old Jul 12, 2003 | 08:48 AM
I all ready have a shift kit from transgo install in it from a long time ago
Old Jul 12, 2003 | 09:19 AM
Colonel's Avatar
sm, how many washers did you use on the accumulator? The more you use, the harder the 1-2 shift. I have the TCI 3500 and their shift kit and the 1-2 shift is plenty firm enough (not part throttle tire chirping, I don't like that.)
Old Jul 13, 2003 | 08:43 AM
well mine feel the ok know I try it 4 the 1st time
and man it feels good and hits hard
Old Jul 13, 2003 | 09:57 AM
Doc's Avatar
Doc
Col, How many washers from the transgo kit did you put in the 2nd accumulator for your aforementioned results? I am in the middle of installing a tci 3000 and am wondering, been going thru posts trying to decide 2 or 3? TIA
Old Jul 13, 2003 | 03:12 PM
well I din't do the job myself I had the trans shop do it
Old Jul 14, 2003 | 12:20 AM
Colonel's Avatar
Doc, I don't know how many washers TCI used when they installed this shift kit. When I had a TransGo installed in my '00, we used 2 washers with the 3500 stall and 3 with the 4600 stall...best I remember.
